Burly Cable Kits?
Burly Cable Kits?
Fellas, I order a set of 14in Tbars for my 2001 superglide fxd. I need the burly cable kit but they don't make a kit specifically for tbars on a 2001 fxd but they do make a kit for apes. So long story short I called Burly and the guy said to look at the specs on their Apes and take a shot at it, and there may be some cable slack depending. So question is has anyone specifically done this? and do you think there will be to much slack and look like ****? Maybe the 12in ape kit will do well with the the 14in tbars because of the width and pullback difference?
For reference the bars and kit
http://www.ebay.com/itm/332099188262
http://www.burlybrand.com/product/47...ow-bottom-apes
http://www.jpcycles.com/product/512-416
You could also look in to Barnett Clutches for cables too. Their prices don't increase from stock to +20" like most company's cables do. I think I had a $100 difference between them and Magnum when I got quotes back from each. I didn't go with Burley because they don't make them to custom length if needed and also heard they aren't the best quality.
Thanks for the tips fellas. After looking into all the options I went ahead and purchased the 12" ape kit. Looking at all the measurements of the burly apes the kit is made for it should definitely work without to much slack. After removing my current bars it was very clear all the cables and the wires are going to be to short. I'll post pictures once I get everything and let you all know how it turns out.
I can get some pictures later today. There's not a large amount of slack with the ape kit but there's some. I wish I would've went a different route but I didn't want to wait and piece together everything I needed at the time. The tbar kit came out not that long ago because it wasn't around when I ordered my cable kit last spring/early summer. Here's a link for the tbar cable kits http://www.burlybrand.com/product/59...as-with-t-bars
