03 bagger clutch slipping
I just bought a new clutch , new friction discs and metal plates . It came with an extra friction disc . Should this be installed ? I only used what came out , it shifts fine ,but when I get on it it slips. The adjustment seems fine what did I do wrong ?? All Harley parts
Welcome to the forum. I guess nobody does a proper introduction any more. Whatever.
My guess: Adjustment, even though it "seems fine"
Here is a good write-up on a new clutch. It is also for a different chain tensioner but you can bypass that if ya don't need it.
I wouldn't leave out any of the disks. The thickness is figured on all of them being there. If you didn't want an extra plate clutch,,,, why spend the extra money in the first place ? If you need extra room leave out the cupped spring in the inside. As shown in this sticky.
Re-count all the stuff you took out. You could easily take out the inner ring & cupped spring & miss putting something back in. Just a thought.
If you follow it you should have no problems.
https://www.hdforums.com/forum/tri-g...-adjuster.html
