Question about gain setting w/DMM
I've confused myself. I am struggling to find the right "V" for my calculations.
JL MHX 280/4 amp running 2 channel bridged into 4 ohm Arc Moto 692.
As I follow the cheat sheet for setting with the 1000Hz test tone I'm overthinking my math.
Calculation 1 - I believe this is incorrect.
50w x 4 = 200W (doesn't matter because I'm not using this)
140w x 2 @4 ohms (bridged) = 280W
P= 280
R= 4
280x4=1120 square root is 33.46 (V)
Calculation 2 - I "think" this is right
140x2 = 280/2 (because I'm measuring one channel?)
P=140
R= 4
140x4=560 square root is 23.66 (V)
Seems to me that 23.66 is the correct V for me to measure. Can someone please verify? The whole bridging piece has me totally lost. I tried!
P= 280
R= 4
P=140
R= 4
Watts per Channel times the load of the speakers - then take the square root
Since you're bridging the amp, you use the rated watts per channel in bridged-mode.
FYI -
From what I've read, those Moto's like and can really handle lots of power. The JL Audio MHX280/4 is under-rated at 140 watts (bridged) with a 4 ohm load. Realistically, it's putting out close to 185 watts RMS. I'd set the gains (with the bike warmed-up & running) midway between 140 & 185 watts, which is 162.5 watts. That would put your target voltage at 25.5 VAC. The square root of (162.5 x 4) = 25.49 VAC
You could possibly go higher, but 25.5 volts will give you a little cushion. That's where I'm running my DD speakers on the MHX - bridged.
P= 280
R= 4
P=140
R= 4
P= 280
R= 4
P=140
R= 4
Man you are doing a heck of a nice job
Pete
Thanks Guys, I just wanted to check and make sure I was using the right number. I set it up today without the bike running but will take it out in the driveway tomorrow and run my tone and DMM again and dial it in. I used the 23.66 because the higher number seems way off so I did it right the first time...now time to fine tune.
Ummmm, don't talk to me about hurrying up...I've been impatiently waiting for Haze's return for a month. I'm about to fly to Miami and give him a ride home from the airport and help him pack up the rest of my gear.
Good on u bro!!!
T.
I like ur strategy on the VAC figure!!! Run this shix within the most restrictive published limits and get to know it. Minor tweaks after u ride for a while will be inevitable as things break in, but damn good idea to identify the smart sandbox and to remain within it!!!!
Good on u bro!!!
T.
Good on u bro!!!
T.
Haze recommended a conservative initial increase up to 25.0 VAC on this amp. I'd also contacted JL Audio with another question, so I took the opportunity to ask them for an "unofficial" maximum gain setting, other than the "published" 23.66 VAC. They told me that the MHX-280/4 (bridged & 4 ohms) should perform well up to 26.0 VAC.
I do agree that a conservative starting point (23.66) might be better. The speakers need a little break-in time before being pushed to their limits and there is always a chance that the DMM isn't reading 100% accurate.
