2016 Road Glide Issue, input needed.
Old 03-26-2017, 08:53 PM
evil-1's Avatar
evil-1
evil-1 is offline
Default 2015 Road Glide Issue, input needed.
Did a search and came up with nothing. My cousin has the bike with the issue, it sounds like a "turbo" spooling up in the primary. We had a new bearings pressed into the clutch spool and the inner primary for the transmission shaft. The bearing for the clutch spool was noisy, so we thought we found the problem and reassembled. Fired it up and "turbo" noise is still there. Looking for any input/ thoughts on what may be the issue. Thanks in advance.
Old 03-27-2017, 03:09 AM
RFG7680's Avatar
RFG7680
RFG7680 is offline
Received 1,280 Likes on 733 Posts
Loose chain adjuster. It's a 16. Let the dealer fix it.
Old 03-27-2017, 06:29 AM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
+1 That's what the warranty is for.
Old 03-27-2017, 04:16 PM
azgrumbles's Avatar
azgrumbles
azgrumbles is offline
If it's only in first gear it's normal.
Old 03-27-2017, 04:29 PM
QNman's Avatar
QNman
QNman is offline
Received 3,706 Likes on 1,987 Posts
Does the noise follow the engine RPM's or the drive wheel?
Old 03-27-2017, 07:07 PM
evil-1's Avatar
evil-1
evil-1 is offline
It's a 15, I miss titled the thread, 3 months out of warranty.
Follows the RPM's.
Old 03-27-2017, 07:15 PM
evil-1's Avatar
evil-1
evil-1 is offline
Tore it back apart. Think it may be a chain issue. Lots of play forward and back and the adjuster was near the top end. Sprockets front and rear are running true, so I'll let you know when the new chain arrives if this solves the issue.
Old 03-28-2017, 05:38 AM
RFG7680's Avatar
RFG7680
RFG7680 is offline
My 11 did that. That's why I said chain. Don't waste time with another Harley adjuster. Get the Baker Attitude Adjuster. I put it in my 11 and away went the noise.
Old 04-01-2017, 08:38 PM
evil-1's Avatar
evil-1
evil-1 is offline
Update: It was the primary chain, it stretched approximately 3/8 - 1/2 inch. Installed the new one and no more noise. Next project tire shredder kit and finish the powder coat! All the parts are in the garage and tear down starts Friday.
BigDogHawg
10-16-2016 09:26 AM
byounghusband
09-12-2014 12:24 PM
jpbo
01-15-2011 07:28 PM
dan conner
10-28-2010 04:31 PM
mccpdx
08-11-2008 12:18 PM
Quick Reply: 2016 Road Glide Issue, input needed.
