Battery connections...
So I have my bike power and ground, 4ga power and ground for the amps, my heated gear connection and now I need to hook up my GPS harness.
I'm sure it will all be fine on the existing post screws but I was thinking of maybe adding an "L" bracket to hold my heated gear and GPS harnesses or maybe adding another power and ground block for accessories.
Thoughts?
Thoughts?
I changed over to a Shoria Lithium battery, I then installed multiple lugs so that my 4g amp feeds have their own terminal. On the main lug I have the bike power, heated gear power and my LED feeds.
I don't think it really matters, but I would say the most important part is to make sure you use properly sized ring terminals on your wires. correct for the wire size as well as correct ring size for the terminal bolt.
Makdaddy (03-27-2017)
I guess I'll just keep using the battery terminal LOL
Thoughts?
Thoughts?
T
