Maintenance Tips Needed For Denim Paint
Hey all.. I just purchased a new 2017 SGS and it came in Charcoal Denim. I love it but have now been reading how hard it is to keep clean and in good shape. especially the older black denim.
I am aware there's the HD cleaner but until I get some, or maybe a better product, I do have some Srayway Glass Cleaner wo/ammonia. Would that be okay for fingerprints and other stuff or just warm water?
Also, when doing a regular full bike wash, is and non-wax based auto soap good or been reading Dawn works good but for the full bike?
And finally, been warned on not rubbing the finish with pressure but just how much wiping force can be used to like get bug guts off? And how much pressure can be used fir regular washing?
ANY tips, help, info would be greatly appreciated
When I had my Fat Bob - it was with the denim black finish - I was pretty **** (still am) about keeping my bikes clean.
You're in the right track - the HD denim cleaner I found worked great. so did non ammonia Windex for wipe downs, clean with normal soap & water - always use a clean soft soap sponge & micro fiber towels.
rubbing of any type firmly and in the same spot - e.g. even a pant leg up against the tank will create a shinny spot
Careful not to scratch as the paint is soft & cannot be buffed out...
In regards to the mention of non-ammonia windex, I have read that the owners manuals, from before harley came out with their denim cleaner, they recommended a glass cleaner WITH ammonia.
It has worked great for me. Just keep it away from plastic, I would recommend using plexus for that.
Edit: straight from a 2010 HD manual
I had a bike for 3 years with the denim black. I never understood all the horror stories about keeping it looking good.
After every ride I wiped it down with the harley denim cleaner to get the bugs and grime off, and washed it twice a year. No problems, paint looked as good as new when I got rid of it. Granted I did not have it 10 years or something, but it was easy to care for imho, easier than gloss black. No swirl marks to build up or watch out for.
It was garage kept however, I did not leave it parked in the weather 24/7. I've seen some denim bikes kept outside that look awful.
Hey all.. I just purchased a new 2017 SGS and it came in Charcoal Denim. Congrats. the charcoal denim is a sharp looking paint.
I love it but have now been reading how hard it is to keep clean and in good shape. especially the older black denim. Dont listen to them. it is not hard to keep clean or in good shape. I had a black denim road glide for 4 years, and over 40,000 miles. it still looked great when i traded it in.
I am aware there's the HD cleaner but until I get some, or maybe a better product, I do have some Srayway Glass Cleaner wo/ammonia. Would that be okay for fingerprints and other stuff or just warm water? The hd denim cleaner is okay, but not necessary. windex with ammonia works just fine.
Also, when doing a regular full bike wash, is and non-wax based auto soap good or been reading Dawn works good but for the full bike? i used waterless cleaner when i cleaned mine, but any car wash soap without shining agents is fine. dawn is a little strong but for occasional use is okay.
And finally, been warned on not rubbing the finish with pressure but just how much wiping force can be used to like get bug guts off? And how much pressure can be used fir regular washing? what causes the shiny spots is friction. if you use something that 'eats' the bug guts off, then you won't have to rub it much and won't cause shiny spots. peroxide works pretty good for that. as well as a large wet cloth just laid on there for a few minutes.
i don't think that's necessarily because of the denim. i've seen some gloss paint jobs that look pretty bad as well.
I had a black denim SG. It's true about the rub marks, so you do need to be careful. The HD denim cleaner is good, so you can't go wrong there. Personally, I use the Sprayway glass cleaner that you mentioned for pretty much everything and it's great. Inexpensive too. For bugs, just spray it on, let it foam up and sit for 5 mins. Respray and wipe off very gently.
