60630-90 vs 60630-94 inner primaries
Old 03-27-2017, 07:29 PM
dibe's Avatar
dibe
dibe is offline
Default 60630-90 vs 60630-94 inner primaries
I found out my inner primary is cracked
Does anyone know what the differences for 60630-90 vs 60630-94 are?
I found a new delkron inner on craigslist for a pretty good price. The guy doesn't seem too sure which model it is. D5000 or D5015. 5000 is for 90-93 and 5015 is for 94-06.
I was just wondering if anyone knew what to look for on the inner primary itself to try and identify which one it might be.
Thanks.
Old 03-27-2017, 07:56 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Why don't you just weld what you have????
Old 03-27-2017, 08:26 PM
aquadave's Avatar
aquadave
aquadave is offline
^^^^^^^what he said ^^^^^^^
Old 03-27-2017, 08:34 PM
dibe's Avatar
dibe
dibe is offline
I would rather get a new one instead of messing around having someone weld it.
Old 03-27-2017, 09:28 PM
RedHogz's Avatar
RedHogz
RedHogz is offline
If not weld....try JB Weld. That stuff is industrial strength epoxy and I'm sure it would more than hold it together and seal it up. It's pretty incredible. I've used this on a Ford diesel oil pan that was porous. Worked well. If you have a stress crack, you might want to stop-drill the end of the crack with a real tiny drill bit to keep it from spreading first.
Clicky:
https://www.jbweld.com/products/highheat-epoxy-putty
Old 03-27-2017, 09:40 PM
texashillcountry
Dirt don't hurt
Thanks.
I looked stock ones up on a parts finder and I can't tell much difference.
The large primary gasket numbers are different so I'm gonna guess the bolt pattern is slightly different but I can't tell from the pictures I could find.
FWIW I found the D5015 at Walmart.com!!!!
https://www.walmart.com/ip/Delkron-D...Case/617837412
Sorry I couldn't be more help..
Old 03-28-2017, 12:17 PM
grbrown's Avatar
grbrown
grbrown is offline
I can't weld to save my life, but as an engineer I would get that welded!
Old 03-28-2017, 12:23 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is online now
Received 47,723 Likes on 18,538 Posts
Old 03-28-2017, 02:54 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,784 Likes on 3,300 Posts
I always thought that when they changed the suffix of a part number that it was just an upgraded part. And that the original part number was still the same part.
Old 03-28-2017, 03:01 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,695 Likes on 1,985 Posts
If they add an "alpha" character to the part number that indicates a revision that is backward compatible. For example 65082-79A supersedes 65082-79, but fits the same application. If the "year" suffix changes (XXXXX-94 versus XXX-90), that indicates a major revision and may not be backward compatible.
Quick Reply: 60630-90 vs 60630-94 inner primaries
