Stripped Torx Buttonhead bolt
Old 03-29-2017, 07:18 AM
Msnyder1112's Avatar
Msnyder1112
Msnyder1112 is offline
Default Stripped Torx Buttonhead bolt
Ugh! I'm so irritated. Last night, I went to install this turn signal relocation kit and what do you know, the third bolt, a t45 buttonhead style, stripped. I'm not sure if I caused it, or if it was there. I'm sure I didn't help.
Anyways, there is obviously some locktite on it, but I can turn it clockwise a little bit, so the inside isn't completely round.
I can get pliers onto the head, I just couldn't turn it.
I'm thinking vice grips, or pound a t50 in there.
Has anyone ever used those Irwin Bolt Grips? My bolts have lines on them, not sure what they are for, but it seems like these bolt grip might be able to grab it.
What do you all think?
Old 03-29-2017, 07:25 AM
Br125's Avatar
Br125
Br125 is offline
Drill it and use an easy out then get a new bolt.
Old 03-29-2017, 07:26 AM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
The Irwins work great, but I'm not sure there's enough meat on a buttonhead for them to grab onto? They kinda suck the bolt head into them as you turn.
Buy them & try them... great to have in the toolbox anyway.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 03-29-2017, 07:30 AM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,344 Likes on 1,550 Posts
Easier to do it to begin with than messing up chrome or paint, then having to drill it out anyway.
After seeing your picture - vice grip would do fine. Didn't realize you had washers and that much clearance.
Old 03-29-2017, 07:50 AM
Msnyder1112
Sorry for the terrible picture. I took it last night. The head actually does have some meat that I think I could grab with vice grips. (Bags are in the way when I took the photo, but those easily can be removed). Maybe there is enough toom for the irwin bolt grip?
Old 03-29-2017, 08:08 AM
psycho dad's Avatar
psycho dad
psycho dad is offline
Remove bag then use vice grips.
Old 03-29-2017, 09:00 AM
sbarron's Avatar
sbarron
sbarron is offline
You won't know until you try. No matter the method, put some tape on the surrounding painted areas for a little protection and let 'er rip tater chip.
shorelasHD (03-30-2017)
Old 03-29-2017, 09:58 AM
Renoir1's Avatar
Renoir1
Renoir1 is offline
Yeah, torx bolts kinda suck. I've stripped my share.
If worse comes to worst, I've had success using JB weld. Take a torx head that will fit in the stripped bolt, goop it with the JB weld and shove it in. I use a strip of masking tape to kinda hold it in place. Let it set a day, then remove. Granted you may be out a torx head, but they're cheap.
Old 03-29-2017, 10:10 AM
Hellbilly562's Avatar
Hellbilly562
Hellbilly562 is offline
Received 13,166 Likes on 5,400 Posts
I used vice grips on one that had stripped out on me.....broke it loose with vice grips and used the torx head to back it the rest of the way out.....
Old 03-29-2017, 10:15 AM
Lakerat's Avatar
Lakerat
Lakerat is offline
I have had some success using a small chisel on stuck or stripped buttonheads. Start off by hitting it straight in near the outside til you get a decent groove started, then tilt the chisel and start pecking.
Quick Reply: Stripped Torx Buttonhead bolt
