Wide glide trees and breakout wheels on my rocker
#41
I know this is not the correct axle, but this is the guy Jo was telling you about, try contacting him?
http://www.ebay.com/itm/Flush-Mount-...4118da&vxp=mtr
#42
There is a bike show locally on October 19th. I was hoping to be done by then so I could ride my bike to it. It's not looking too good right now.
When I mocked up the spacers for the front wheel today the exhaust side spacer looked like it was gonna be too short.
#43
Sorry this took so long but here it is (went out of the house for a bit)
and another quote from trust, he's still around on the forums so he might be able to give you a heck of a hand with the axle. I used hhi's axle and wideglide spacers for the fat 50's (trying to get an answer on what spacers to get was a huge deal like 8 phone calls if i rememeber correctly)
thread is located here: https://www.hdforums.com/forum/softa...el-pics-6.html
hay tree,
yah thats the trees i have. i bought the axle kit too but was a waste of money for me cause since i went with custom wheels i didnt need the rotor spacer or fender spacers i only used the axle but they didnt send me the sleeve that goes in the fork tube. your stock axle has a bolt that holds it together, there gonna a send u a stock 25mm wide glide axle with male threads they didnt send me the nut and washer either but jeff took care of it for me. if your gonna use the stock wheel i can send u the whole kit for $20 u will need a axle (41547-07A) $64.99 axle nut (7813A) $1.49 washer (6655) $.99 and your gonna need that axle sleeve for the fork leg which u can get from hhi or have one machined the dimension for that is .984 od .750 id and 1.375 in length. also the bottom tree is drilled and tapped for a internal stop i used the pro-one internal stop theres 2 slots on the stop just make sure u bolt it on the trees were the shorter slot is towards the rear of the bottom tree so the trees wont hit your gas tank when u turn your bars. its very simple to install if u call and cancel your axle kit youll save some money the kit i have is brand new and u can get the axle and etc from ronnies mailorder thats where i got the price s from. let me know if i can help
#44
#46
So basically TRUSTNOBODY put a sleeve in the fork leg, then ran the smaller axle end through that. That's a good idea, you just need to find a machine shop that can make you a sleeve to fit in there.
I'm not sure what he means about flush mounts with their "allen bolt design". There is no allan bolt on my flush mount? You use a 3/4" socket on the end of it to tighten it up.
#47
#48
#50
Turns out my next door neighbor has a lathe in his garage. Didn't need to search for a machine shop!!!! Another shout out to my neighbor Bob lolol.
Here is the sleeve we made. O.d. Is 25 mm and i.d. Is .750. Those are the dimensions I got from TRUSTNOBODY.
We didn't cut the sleeve to length yet since I don't have the breakout axle (Gonna go on Monday and see if the stealer has one in stock) and I want to make sure we don't cut it too short.
Cross yer fingers !!
