Air ride...modification to set frame on ground
I'm researching and putting ideas together to modify my 14' Breakout so that when I bleed the air out of the ShotgunShocks, I'm able to set it on the ground and the bike will set level.
At the moment, I'm thinking about fabricating a retractable H shaped stand that is mounted under the frame that would be spring loaded and allow me to kick it down before I bleed the air out. Of course, it would have to be centered perfectly, stable, and wide enough for good stability.
I'm curious to see if anyone has any experience or has seen kits for softails...or even have an idea of your own of a good way to accomplish this modification.
I'm not dead set on doing this, just gathering some ideas. I've attached a picture of the H-shaped stand which is similar to the concept that I'm thinking of.
All replies, good, bad or insulting are welcome...heheh
Johnny Goodlife (02-10-2017)
I am going to look further into this myself over the winter for my Rocker. To actually have it sit on the frame would be a ton of work on the frame and swingarm, so I was thinking of something similar to your idea to be cheaper and easier. Basically, get a center stand and shorten it. Problem I am finding is that no one makes a center stand for a Rocker that I can modify, so looks like that will be done from scratch. The hard part is going to be mounting it. Not a lot of room left with the shock and compressor already mounted under there.
Good point too, I worded this thread incorrectly and I need to edit the title.
Jim: I think that you're going to have to spend a pretty penny to get that look (which I think is pretty cool). You'll need to get air for the front as well as the back and will most likely have to have a swingarm made. Please start a thread of this project if you decide on it, I'd be real interested in what it would take to make this happen. Good luck!
