Cardboard or gotsaggybags
gotsaggybags or carboard
I have a 2014 Heritage Classic and didn't want Texas weather to start deteriorating the leather saddlebags. And, I don't like the saddlebag deteriorated look. As a former KLR650 rider I'm always thinking of doing upgrades on the cheap. "You spent nearly $20k on a motorcycle and you're using cardboard found in a school dumpster to line your leather bags! exclaimed the wife. Ouch! It just so happens that I went for a ride to the Bedford's HD dealer. By the by I asked the counter dude if they carried anything to stiffen leather bags--Presto! Out came Yougotsaggybags kit for $119. I bought them on the spot as they were cheaper at the dealership than ordering from the manufacturer (no S & H charges)--and, I had already done my research on them. These were the ones I wanted. Immediately, I headed home to start the job.
It's a straight-forwarded job but it takes time to wedge the plastic parts between the seams--you will wrestle with the install a bit--you just have to experiment which way will work for you. Instructions are clear, but here's a bit of advice: Have four small weights and two pieces of wood to weigh down the lids that are glued son. The glue dries fast so you don't want to scurry about looking for weights or wood once you apply the glue. Instructions say you need about 40 lbs; I used about 25 and they came out fine. Gluing is the trickiest part so dry fit everything first.
Okay, as I mentioned before I do everything on the cheap. But, folks these Yougotsaggybags kit is a fine piece of engineering. Everything fits so tight and precise (you may have to trim/cut here/there), and all pieces are held together by pressure (except the lid that is glued). This is not ordinary plastic; you'll have to try very hard to break it.Yeah, I know-- lots of guys are like me, but in this case I'm glad I shelled out the $119, sweat, and a couple of sore fingers. My leather bags are firm, no sagging, and based on what I've read from other members, my bags will stay looking good for years to come. Next step is to use HD saddlebag cleaner and protectant to keep them looking showroom new. I say take out your homemade stiffners and get these--you won't be disappointed and you'll avoid your wife's scorn. Pix 1: removed cardboard inserts; Pix 2 front rail; Pix 3 the perimeter--this keeps parts in place; Pix 4 weighing it down; and, Pix 5 Finished with firm, plump bags.
Received 3,389 Likes
