Added new fat spoke rim
Old 10-09-2014, 06:53 PM
lowebudget's Avatar
lowebudget
lowebudget is offline
Default Added new fat spoke rim
Installed new DNA fat spoke wheels and now my front end feels clunky for lack of a better term. I feel like since the install the front end bottoms out and makes s clunking noise on even the slightest bumps. I haven't noticed the fork seals leaking? Any suggestions?
Old 10-09-2014, 11:08 PM
sLow5Rider's Avatar
sLow5Rider
sLow5Rider is offline
Attachment 402426
I hear the same clunking on mine. Started when I put in 2" under tubes and lowered another 2". It's not bottoming out for sure. I was starting to think my neck stem was loose. Oil is leaking from the top of my forks so I'm thinking it's making the sounds because it's low on fork oil. I'll be tearing mine down this weekend and filling. I'll let you know if that changes anything.
Old 10-10-2014, 08:09 AM
S.D.M.F's Avatar
S.D.M.F
S.D.M.F is offline
Also check the headstem bearings the grease needs to be re-packed every now and then.
Good time to check the fall away at the same time.
Old 10-10-2014, 08:18 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
Not sure about the clunk, but I do like the look with the rims.
Old 10-10-2014, 02:32 PM
oct1949's Avatar
oct1949
oct1949 is offline
What else did you do to the front end??
just changing wheels should not cause anything, unless you put the wrong size axle for the wheel bearing size back in ...
Old 10-10-2014, 03:35 PM
lowebudget's Avatar
lowebudget
Nothing else done to the front end. Simply swapped the wheels. Bearings came in the wheels. When I get home I'm gonna check the bearings. Maybe I got a bad set even though they should be new.
PanHeadRich
EVO
222
05-01-2019 06:19 PM
agove
04-12-2015 04:08 PM
Vato_FXDB'07
09-10-2012 05:26 AM
cactusred
07-05-2012 06:03 PM
cactusred
12-15-2009 07:21 AM
Quick Reply: Added new fat spoke rim
