Freedom upswept Exhaust on Softail Slim
I have the upsweeps on my FatBoy, same basic frame and funny you should post this today since I just got done modifying my passenger pegs to fit mine today. The pipe will not allow you to fold up the peg, I had to add a 2" extension on my peg mount to fix it so it could fold. I also had to grind a notch in the original mount to clear the heat shield on the rear pipe. Nice thing is it kinda looks like a kick starter. Luckily I don't usually even have the pass pegs on since I have another bike to ride two up and don't need them. did this for emergencies. Added a pic of a slim with the shark tails on it I took at a dealer, he didn't have pass pegs on either.
I have that exhaust on both my Slim and on my wife's Lo. It's bitchin', but I don't know that I'd want to ride a passenger with 'em - pretty close to leg/butt, and probably loud as heck, too. In fact, I won't ever have a passenger on either of the softails because of that, but I have the Road King for any 2-up riding I want to do.
Here's an old photo of my bike, another, closer up for the area the peg will mount to, and a last one with both the Lo and the Slim. Hope this is helpful...
Oh, one last thing - the instructions for my exhaust were for the old version. Still worked, but there was no mention of the O2 sensor bung adapters. Unless they have changed the exhaust again, the sensors on your Slim are the smaller (8mm?) ones, and the bungs in the pipes are for the larger ones (12mm?). There IS a pair of adapters in your hardware kit. There is NOT a new set of exhaust gaskets, so you might want to grab a new pair. Go with the usual conical ones, not the Screaming Eagle ones, which are flat, and I had a problem with them sealing, resulting in a leak.
Hey, Gunny... on the wife's Lo, we just stripped the turn signals off, and went with a Custom Dynamics LED tail light with integrated ones. We'll eventually put on some Alloy Art strut end LED turn signals, too... but yeah, the stock ones don't really play nice with the upswept pipes. As you mentioned, the signals on the Slim are far enough forward that it's not an issue. I changed out my lenses with some Autogem glass ones - wonder if that would solve your problem, still be an issue, or if they'd even fit.
Bowen0200
12-06-2018 02:57 PM
