sealing a leaky 60 spoke wheel on rocker?
Hey guys,
I'm running an 18x8.5 60 spoke on the back of my rocker. The wheel was supposed to be tubeless but when I got the tyre put on it leaked like a sieve.
I'm running a tube as a short term fix but does anyone have any recommendations for sealing it up to run tubeless?
Thanks,
MAtt.
Thanks,
MAtt.
You're not going to get a tubeless spoked wheel with out making it a hack job, thats the nature of spoke wheels. There is a little gap around the nipple and where the spoke and nipple thread that air can get through.
But I have seen a guy use a rim strip and lots of silicon to seal up a spoked wheel for tubeless application, but the problem with that is you're adding weight and later balancing.
So, I'll probably go down the silicone based sealer road. I found these online...
http://supermotojunkie.com/showthrea...-with-pictures
http://cyb.smugmug.com/Motorcycles/K...less/i-BjwM3St
Second option seems a bit more thorough. I might try it.
Still difficult to understand your explanation.
Reason: the factory tubeless spoke rim requires a sleeve..is this a factory rim and if it was a factory tubeless rim then the sleeve should have been changed.
Aftermarket rim is another story.
Ride-on will not function in this application since the forces during rotation make the product stick to area closest to road contact (product moves outward) and not the rim
