Trucklite passing lamps Napa part number?
We have them in stock and on sale. If you enter the coupon code Forum5 at the checkout it will take off another 5% too.
Passing lamps only
http://www.easternperformance.com/tr...-housings.html
Headlight and passing lamp combo
http://www.easternperformance.com/tr...-lamp-set.html
Passing lamps only
Altho the part number is for trucklite for sure, did you verify it? It's there even any way that it could be anything else?
I picked it up. I also bought the visor trim ring from harley. I couldn't get the ring over the lamp with the original 3 screw mounting piece. After struggling for awhile I eliminated the 3 screw ring, and it went on easy and tightened right up. I also removed the rubber from the visor. I purchased 2 /50watt halogen bulbs for the passing lamps. Huge difference. I found a couple of par 36 yellow lenses from some pin spots. They wouldn't fit in the trim rings so I got the visor rings for the passing lamps. I filed the lenses a bit around the edge and was able to press them over the passing lamps from the outside. Nice upgrade for not too much cash. The visor trim rings look good on the heritage.
can someone chime in?
