Rear brake not working
Like Gman said, the issue is probably related to either low fluid or more than likely air in the system.
For some reason I seem to have to bleed my brakes about once every year.
The pedal over year's time frame progressively softens up.
I've just added this to my "to do list" when I'm changing the fluids.
I'm guessing that my problem is a weak seal at the reservoir , but also like Gman said, bleeding the brakes is easy and only takes a few minutes once you have the "tube", "wrench" and bottle of fluid handy.
Also like Gman stated, if you haven't already it's time you drop $60 on a service manual.
