Cutting Handlebars
Cutting Handlebars
Carlini bars are in and so is Exile internal throttle. Read quite a few posts on this install but no description of types of tools for cutting handle bar off 4" for the Exile install. Any recommendations on tool for cutting? Also, I see Dremel work for opening up the ID, but recommendations on the stone or bit?
Getting ready for the winter project. Any help would be appreciated.
robc
robc
Received 4,926 Likes
I used a medium sized tubing cutter, same as used for plumbing pipe. Takes a few minutes to score through, but leaves a nice clean, perfectly square cut.
I used a dremel as well, don't remember what bit I used though. Probably just used up every bit I had in the box until I found one that worked pretty good. I also used the engraving extension wand thingy to easily reach far enough into the tube. Takes awhile, bring a couple beers out to the garage.......
Tubing cutter would have been nice. I just wrapped the bars with blue tape where I wanted my cut and then just followed the line with the saber saw. The internal throttle and clutch will slip into the 1" tube about 2 inches so it will align itself straight. If your cut is off you will see it and be able to clean it up with the grinder.
