Patriot Defender Exhaust Anyone?
They work well, Mine has been on since 2012 and has held up well (close to 40,000 miles.) The adjustable baffle does vary the volume, but if you don't move it back and forth regularly, it will seize up and become permanently stuck.
Adjust your fuel ratio for where you'll ride it as far as the baffle goes, or adjust it when the baffle is wide open and let it run a little rich when you have to close it up.
Good product at a very reasonable price IMO.
I have one as well. Love it. I ran a clutch cable up to the bracket where the horn goes so I can open or close it by pulling the cable, made a handle out of some .22lr grips from my NAA pug. I live in a nice community and don't want to **** anyone off. It sounds like a little Honda when it is closed, and roars when open. Best of both worlds. I have a VH fuelpac and they have a set of codes for it. I have not seen any difference in performance when it is closed.
Pull handle
Here is a pic of the pull handle
Pull handle
I'm happy with this one after 3 years. It came with a ?flexible? ?springy? piece of piano wire to fix the adjustment instead of a cable. I set the valve all the way closed and like the sound there. I think as the RPMs pick up the exhaust pressure pushes the valve open more.
Night train patriot defender exhausth
I have a night train and looking for a good value exhausth and patriot defender seem to be that, performance tunable sound affordable price.
i can only see picture on chrome motor can you show side picture of your night train with it please?
best regards
