replace clutch lever on FXSTS
slide down the rubber boot that covers the adjustment bolt ( front of frame / below gas tank ) ...undo lock nut and twist the adjuster to loosen the cable as much as possible . there is a small clip under the pin on clutch lever perch....remove it carefully . remove the pin and slide out the lever....remove the brass cable pin and remove the lever . reverse to install .
Watch this:
U-tube is your friend - If this doesn't tell you enough - Keep looking on-line
Watch this: Motorcycle Brake & Clutch Lever Maintenance - Step by Step - Video Guide: Tip of the Week - YouTube
.....would be ok if he owned a Kawasaki
The easiest way to replace the clutch lever is to remove the old one first. Just pulling your chain.
I'll ask the obvious question. Do you have a service manual for your '06 Springer Softail? If not, it's time to get one. It's the best $48 you'll ever spend.
http://www.kutterharleyonline.com/ha...anual-99482-06
Before you ask, HD manuals only come in hardcopy from dealers (ie: you cannot download them). This is the best price you'll find.
_________________________________________________
The pearl for removing the clutch lever is this:
DON'T lose the retaining (snap) ring that holds the pivot pin in place.
Damion
03-27-2012 06:49 AM
