cruise control
What he said. Wish they did, my right hand literally hurts after just a short time at the same throttle position. My other bikes have cruise and it makes all the difference on a road trip to be able to swap hands
I've got the Kury ISO grips with the throttle boss. It makes all the difference in the world. I can ride for 14 hours a day without wrist problems, and I suffer from RSI when typing.
Those little friction wheels under the throttle are rubbish. If you've ever changed your grips, you'll see that they just rub up against the throttle inside, so wear away over time. The simplest, workable solution that I've seen is just basically a peg that grips around your grip, and rests on top of the brake lever. Once up to speed, you just push it down onto the brake lever and it holds it there. You can still open the throttle more to overtake, and if you push the throttle closed, it will slow down. A very simple idea.
http://www.thingiverse.com/thing:111272
EDIT: I'm in the process of building a 3d printer, so I'll definitely be having a go with this once it's up and running. I'll let you all know how I get on. (But I'm sure there are people selling this kind of thing on ebay. I'm in the UK, so postage is going to be the biggest part, but could otherwise sell them at cost if others were interested.)
Yep. Just one cable - "Stepper" cable from module to Throttle body. I did not use idle cable with cruise cut-out switch because that seemed to be source of biggest problem when it quit working on most other bikes.
I used the 3rd function on the volume/mode switches from the radio switch kit to act as the kill switch.
Steve
Steve
I know it's pricey, but the cruisemounts solution is a great one. Dave uses Harley parts and buildsee a setup for the Softail. My dad ordered one for his '08 Heritage, and absolutely loves it. I bought an '07 FLHT that didn't have cruise. I bought a cruise system that I thought would work, but was good up to '06. Harley changed the connector for '07. I called Dave at cruisemounts, told him my conundrum, and he offered to build me an adapter harness, or just sell me the connector and pins. I went with the connector and pins, then had one of our avionics guys fix it up for me. My point is that Dave puts out a great product, and is a pleasure to deal with. He's more than happy to help in any way.
