Cutting Vance and Hines?
Been there done that. I once shortened a set of Long Shots and ran them wrapped with thermal exhaust tape. Easy project.
Remove the pipes from the bike. Remove the Heat Shields and Exhaust Tips. Mark where you want the cut. Try to find a larger diameter pipe and slip it over the end of the exhaust to use as a cutting guide. This will aid in achieving a square cut. Use a file to clean any burs from the cut.
If you plan to reinstall the exhaust tips, you'll have to drill holes for the attachment screws. Note: Vance and Hines manufactures the end of the exhaust tips to be level with the heat shields. If you mount the tips without the shields, there will be a height difference, however if you wrap the pipes all the way to the tips this outside diameter difference will not be visible.
