shotgun V legend
03-03-2015, 12:31 PM
Quote:
Originally Posted by
Ramboamt
You don't need to "Pull out the unit" to change the tranny oil only drop the front of the shock unit down to get to the drain plug.
Shotgun ALLLLLL the way.....
oh thats cool, thanks
03-03-2015, 12:35 PM
Someone on here recently reported success using one of those vacuum pumps - the honey-sucker tube stuck down the filler hole.
03-03-2015, 12:49 PM
1004ron
imma look into that
03-03-2015, 08:11 PM
03-03-2015, 09:18 PM
1004ron
It was one of these that he used, and much to my surprise it worked for the trans.
If all you are looking to do is suck the fluid out, just stop by wally world and pick up an oil pump for $14.
http://www.walmart.com/ip/Gas-Oil-Siphon-Pump/39105532
03-03-2015, 09:26 PM
03-04-2015, 06:45 AM
They also make an after market side tranny cover with a drain plug in it. Had I not stayed with a Harley SE side cover I would have gone that route when I switched over to a hydraulic clutch.
03-04-2015, 07:23 AM
03-04-2015, 08:14 AM
ILMFBL
Search engine sucks.
use Google instead.
type in your search string and include 'hdforums' in it.
ie;
hdforums shotgun legend
much better results...
03-04-2015, 04:45 PM
Just know that once you respond to an older post you'll get the guys that complain you responded to an old post. Can't win
For the record, I've used both, SS and 420 progressive on my Slim. Different animals, but in the end I'm still riding the progressive and wouldn't change.
