2014 soft ail fuel tank removal
Old 03-29-2015, 04:41 PM
kazharley's Avatar
kazharley
kazharley is offline
1st Gear
Default 2014 soft ail fuel tank removal
Hi,guys
i recently purchased a 2014 heritage softail classic. I am having problems removing the gas tank. I have removed the acorn knot on the center console, removed the front bolt that holds the tank to the frame, and the back bolt by the seat. I can't seem to be able to remove it. The center console also does not move.
Anyone know how i can fix this? It seems there are more bolts that need to be removed so I can move the center console than just the acorn. I need to access the turn signal wires under the gas tank to install LED mirrors. I am almost there.someone pls help.
Thanks
Old 03-29-2015, 05:48 PM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 10,858 Likes on 4,112 Posts
Welcome to the forum.
The first item you need is a 2014 Softail Service Manual. You must get it through a dealer. It is a mandatory part of your toolbox as you are finding out.
One or more of the links in this search will help you
https://www.google.com/#q=removing+h...+tank+hdforums
Old 03-29-2015, 06:20 PM
kazharley's Avatar
kazharley
1st Gear
Thanks for the web site.
Old 03-29-2015, 06:24 PM
SGMongoose's Avatar
SGMongoose
SGMongoose is offline
so you can't get the console off? the acorn nut is the only thing holding that on.
Old 03-29-2015, 06:33 PM
kazharley's Avatar
kazharley
1st Gear
yes,consol won't budge with the nut removed. i even tried prying off with a flat head.
angeltrash1
01-28-2018 04:31 AM
hd-kw
09-12-2011 12:23 PM
gartec81
05-15-2010 08:42 AM
t059736
03-03-2010 08:33 AM
Motown_HOG
06-27-2007 11:09 AM
Quick Reply: 2014 soft ail fuel tank removal
