Custom Dynamics LED lighting kits?
I have the C.D. LED turns all around, plus I added an additional NightRiderz LED light bar under my rear fender used as a run/brake light, since the Slim didn't come with one.
Between the rear turns and brake light, my running lights are now far brighter than the stock incandescent brake lights were - and when I do hit the brakes it's like OMFG.
I'll never own another bike without doing this upgrade - these things WORK, at keeping tailgaters off your ***, plus they're impossible to miss provided drives are even mildly attentive.
Idiots on cell phones will still wreck ya though since, you know, they're morons.
So... you still gotta keep your head on a swivel, but the LED's do help, a LOT.
Just started researching these and have a question. I have the OEM standard bullet turn signals on the front and rear. If I add the rings to the front signals will the outer ring stay on as running lights? If so I am assuming the wiring harness they come with must some how open that power circuit for juice whenever the ignition is on. Also, do they add much significant light to your headlight when driving at night? Thanks much.
My '08 Deluxe was that way, anyway. I haven't ridden yet (just installed a couple weeks ago, roads finally got salt washed off a couple days ago) with them, so can't comment on additional light for seeing from them - my guess is they will not really help in that regard. Definite improvement for making you visible to other drivers though.
striper.seeker
2014-2023 Touring Models
13
06-17-2016 05:03 PM
