FXSB Breakout Upgrade DIY: Fork Suspension / Tires / Brake -Part numbers, tools, tips
#151
Should work fine- I would call Ricor if you can, they unfortunately don't answer emails much. The parts will fit but you'll need to know how much fork oil to put in. Be sure to use 5w fork oil and not 10w, sometimes one of the jr tech's at Ricor will say get 10w but for Rocker / Breakout it is 5w.
I don't think there is any difference in length of fork tubes between Rocker and Breakout so I'm anticipating you could use the same amount of fork oil as I outlined for Breakout. Member 'Rocker B' might know since he owns both.
Never get progressive-rate front fork springs. in any bike (JMHO). Go with the exact RaceTech single rate springs as for the Breakout.
422's are better than stock and are an ok value if you can find them on sale. I just think they are a total rip for what they are trying to sell them for full price. Still seems that ShotgunShock is the best all around ride from what I keep hearing.
TOMMYBLAZIN (10-14-2016)
#153
#155
Yes if you want to get all of it out that is how you do it. IMHO it is not worth the time or effort to do so, the benefit of adding heavier fork oil is minimal. while the damping can be slightly improved with the heavier oil, it won't do a lick of good for those soggy dual stage springs - which is the main problem.
We're not talking a lot of $$ here for the full upgrade if you are going to DIY- maybe wait a bit or the cash then just do it?
#156
Thanks LA-dog will wait till i recover from pulley swap then do springs ect
#157
Received 1,934 Likes
The RaceTech video makes for a good understanding and when you really think about it, all a thicker oil can do is provide a "slower" collapse rate at the expense of efficient bump absorption.
Without somehow introducing variable aperture, direction/velocity sensitive valving, all you have is fixed aperture damper tubes through which oil will squish back and forth, with a resistance which must increase with oil velocity. This is simple physics. You want just the opposite to occur. Introducing even a modest product like the Intiminator, allows for differentiating based on oil flow direction/velocity and maintaining higher oil flow resistance against low velocity fork collapse while offering less resistance to rapid oil velocity bump absorption.
"Worth the wait".
#158
If you get the exact parts, have basic tools / jack needed, and follow the install steps on page 1, it will take you 3hrs start to finish - and that is working at a careful leisurely pace with a few cold ones. You'll probably have to pay a bit more for shipping on the Ricor dampers and RaceTech springs but fortunately they don't weigh much
#159
i thought you already did the forks ?
#160
