FXSB BREAKOUT - Project (Almost) Completed
Old 04-15-2015, 01:47 AM
Nostradamus74's Avatar
Nostradamus74
Nostradamus74 is offline
Default FXSB BREAKOUT - Project (Almost) Completed
Hi guys!
After about one year and a half of continuous mods, nearly 100 parts upgraded and installed, custom paint and tons of chrome, finally my Breakout project should be finished…at least until I won’t find some more inspirations and start again another series of endless mods! J For the moment the only missing mod I planned to install is Shotgun Shock with handlebar controls.
Just picked up the bike yesterday from the dealer were parts have been installed and have to wait for the flush mount gas cap to be installed as I had on stock gas tank and Airfoil pegs still on backorder to match grips. Will also slam a little bit more the rear end...
I wish to thank all of you who have been a source of ideas and tips but in particular EagleRay who has been my “alter-ego” in sharing ideas and studying mods together, and Pigbacon who offered his generous and precious help in supplying parts from overseas, allowing me to complete the project! Thanks Bros! J
I tried to maintain and even enhance what I consider the original spirit of the Breakout, a low contour, a “drag-style” minimalism and a “hot-rod” soul. Also tried to concentrate my attention on smaller details to match the look and cleaning up as much as possible the overall silhouette.
Hoping to make something useful I attach the complete list of mods and parts installed with their part numbers, divided into categories for a quicker search and identification, in case someone should be interested in using them as a reference.
I’ll post some updated and more detailed pics as soon as I'll manage to take them as well as updating the parts list.
Since they’re by far the vast majority, unless otherwise stated, parts should be intended as OEM HD.
HANDLEBAR, CONTROLS,GRIPS & LEVERS
Chromed (by Sport Chrome) Stock Handlebar 55800215
Switch Housing Kit (Chrome) - 71826-11
Switch Cap Kit (Chrome) - 71500110
Hand Control Lever Kit (Chrome) - 45075-07
Clutch Bracket and Master Cylinder Reservoir Kit (Chrome)- 45355-08
Clutch Ferrule & Banjo Bolt Cover Kit (Chrome) - 32714-98A
Clutch Ferrule & Banjo Brake Bolt Cover Kit (Chrome)- 41300061
Billet Handlebar Riser Hardware (Chrome) - 63026-05
4 in. Combination Digital Speedometer/AnalogTachometer - 70900100B
Gauge Visor Ring (Chrome) - 74662-04
Tailfin Custom Mirrors (Chrome) - 91696-05A
Stealth Hand Grips (Chrome) - 56729-04
Arlen Ness Polyurethane Handlebar Riser Bushings
Billet Rear Brake Lever (Chrome) - 42632-07
Billet Style Shift Lever (Chrome) - 34539-00
Thunderbike Flat Riser Kit (Chrome) - 51-72-010
PEGS
Slipstream Footpegs (Chrome) - 50500091
Slipstream Shifter Peg (Chrome) - 33600008
Slipstream Small Brake Pedal Pad (Chrome) - 50600037
Passenger Footpeg Support Kit (Chrome) - 51039-05
AIR CLEANER
EFI Intake Manifold Cover (Chrome) - 27483-07A
Forged Billet Air Cleaner Cover (Chrome) - 29745-00A
Billet Air Cleaner Side Insert 97005-02
Skull Billet Air Cleaner Medallion (Chrome) - 29833-06
Stage 1 Twin Cam Air Cleaner Kit 29773-02C
Air Cleaner Back Plate Kit (Chrome) - 29510-05
COVERS & INSERTS
Skull Derby Cover (Chrome) - 25441-04A
Skull Timer Cover (Chrome) - 32975-04A
Headbolt Bridge (Chrome) - 43858-00
Tappet Block Accent (Chrome) - 61400002
Rear Axle Nut Covers (Chrome) - 43000051
Smooth Cylinder Base Cover (Chrome) - 32042-07
Inner Primary Cover (Chrome) - 60815-08A
Cover LH Side/Pivot Shaft (Chrome) - 48848-09
Cover RH Side/Pivot Shaft (Chrome) - 48804-09
Contoured Frame Inserts (Chrome) - 48212-08
Fuel Tank Fitting Cover (Chrome) - 62809-06
ENGINE & EXHAUST
Screamin’ Eagle Pro Super Tuner 32109-08C
Screamin’ Eagle 204 Cam Kit 25464-06
Screamin’ Eagle Perfect Fit Pushrods 18400-03
Screamin’ Eagle High-Volume Oil Pump 62400001
Screamin’ Eagle Heavy Duty Clutch Spring 37951-98
Screamin’ Eagle High Performance Inner Cam Bearing24018-10
Screamin’ Eagle Cam Service Gasket Kit 17045-99D
Screamin’ Eagle Cam Spacer Kit 25928-06
Screamin’ Eagle Drive Gear Retention Kit 25566-06
Arlen Ness by Magnaflow Lowdown Exhaust (Chrome)
WHEELS & SPROCKET
Chromed (by Sport Chrome) Gasser Stock Front Wheel43300210
Chromed (by Sport Chrome) Gasser Stock Rear Wheel40900206
Turbine Billet Sprocket (Chrome) - 42200007
CABLES & LINES
Diamondback Throttle/Idle Cable 38781-06
Diamondback Brake Upper Cable 41800053A
Diamondback Brake Lower Cable 41800308
Diamondback Clutch Cable 38849-09
Billet Clutch Cable Adjuster Dust Cover (Chrome) - 64108-03
Braided Stainless Steel EFI Fuel Line 63020-04
Braided Stainless Fuel Crossover Line 63692-00A
Throttle Cable Clip (Chrome) - 91274-04
Braided 8mm Spark Plug Wires (Chrome)
BRAKES, CALIPERS &ROTORS
Front Caliper Kit (Chrome) - 44395-08
Rear Caliper Kit (Chrome) - 42047-08
Rear Caliper Bracket (Chrome) - 42048-08
Rear Master Cylinder Cover Kit (Chrome) - 41777-05A
H-D Script Brake Caliper Insert (2) (Chrome) - 44476-99
Turbine Rear Floating Brake Rotor (Chrome) - 41500069
Turbine Front Floating Brake Rotor (Chrome) - 41500070
TINS
Stock Fuel Tank 62322-11, Custom Painted
Stock Front Fender 58900042, Chopped and CustomPainted
Thunderbike Rear Fender with Integrated LED Taillightand Turn Signals 72-72-128, Custom Painted
Softail Front Spoiler 57040-08DH
ACCESSORIES
Chromed (by Sport Chrome) Stock Swingarm 47694-11BHP
Chromed (by Sport Chrome) Oil Tank 62500015
Chromed (by Sport Chrome) RH Fork Slider 45500161
Chromed (by Sport Chrome) LH Fork Slider 45500159
Chromed (by Sport Chrome) Blackline Console 71340-11
Blackline Console Conversion Parts 72775-11, 71576-08A,60900001
ABS Harness Cover (Chrome) - 32700002
Lower Belt Guard (Chrome) - 60654-07
Flush-Mount Fuel Cap (Chrome) - 61100006A
Voltage Regulator (Chrome) - 4567-11
Skull Gear Shift Linkage (Chrome) - 34850-09
Speed-Check Transmission Dipstick (Chrome) - 37103-08
Oil Level & Temperature Dipstick with Lighted LCDReadout (Chrome) - 63002-09
FXSBSE Forward Control Shifter Bracket (Chrome) - 33749-07A
FXSBSE Chrome Forward Control Brake Bracket (Chrome) -50600088
Delta Parts Storm Flat Side License Plate Holder(Chrome)
Flush-Mount Front Axle (Chrome)
SEAT & BAGS
Thunderbike Seat Plate 11-72-250
Thunderbike Custom Made Seat
Thunderbike Passenger Pillion Pad with Suction Cups
Swingarm Bag with Willie G Logo
Tool Bag with Willie G Logo
LIGHTING & TURNSIGNALS
Chrome Billet Headlamp Shell 67704-03
5-3/4 Daymaker LED Headlamp 67700144
MBW Wrap Around LED Turn Signals (Chrome)
Thunderbike Load Equalizers (3) 41-99-655
SHOCKS
Progressive Shocks 422-4037C
Attached Thumbnails FXSB BREAKOUT - Project (Almost) Completed-img_5771.jpg   FXSB BREAKOUT - Project (Almost) Completed-img_5774.jpg   FXSB BREAKOUT - Project (Almost) Completed-img_5782.jpg   FXSB BREAKOUT - Project (Almost) Completed-img_5779-copia.jpg   FXSB BREAKOUT - Project (Almost) Completed-img_5778.jpg
The following 2 users liked this post by Nostradamus74:
artkoral@live.com (01-16-2022), HKMark23 (05-27-2016)
Old 04-15-2015, 04:43 AM
usmcbuck's Avatar
usmcbuck
usmcbuck is offline
I'm a chrome guy myself, really dig'n all that you have done. The bike looks awesome!
Old 04-15-2015, 06:45 AM
jtaliani's Avatar
jtaliani
jtaliani is offline
Not only an impressive project, but that is the most impressive mod list write-up I've seen. Excellent cataloging of your extensive upgrades!
Old 04-15-2015, 07:53 AM
Alain's Avatar
Alain
Alain is offline
That thunder bike rear fender looks nice
Old 04-15-2015, 09:03 AM
super2kc's Avatar
super2kc
super2kc is offline
Holy thats a beauty.
Everything came together perfectly.
Nice Job!!
Old 04-15-2015, 03:43 PM
Harleyvetteguy's Avatar
Harleyvetteguy
Harleyvetteguy is offline
I'm with Alain - love the rear fender. The whole bike looks fantastic! Great job!
Old 04-15-2015, 05:40 PM
Sport Chrome's Avatar
Sport Chrome
Sport Chrome is offline
Former Sponsor
Great job. Happy to have been involved!
Old 04-15-2015, 08:40 PM
Pigbacon's Avatar
Pigbacon
Pigbacon is offline
That is one bad bike! Glad I could be of assistance to you my friend.
Old 04-16-2015, 01:35 AM
redeye93's Avatar
redeye93
redeye93 is offline
That thing came out sweet! Very nice! Congrats on a great project!
Old 04-16-2015, 04:06 AM
psdj52's Avatar
psdj52
psdj52 is offline
Wanted to know how you like that Magnaflow Lowdown exhaust? Would luv to hear a sound clip. Gorgeous bike and Congrats.
Quick Reply: FXSB BREAKOUT - Project (Almost) Completed
