New Exhaust Fit Issues with Stage One
Hi All,
Looking for some suggestions. Just did a Stage One on my 14 Deluxe. Put on VHBSS and SE high flow Billet ( choose this because I liked how it looked)and Dyno.
Bike sounds great and performs great but in my infinite wisdom and didn't realize how far our the high flow sticks out making it uncomfortable and hard to reach brake. I should have listened to the tech and got the base hi-flow.
Is there a fix to move the brake pad out about an inch as well as the right board?
thanks in advance for your help.
Moving the boards out, not quite an inch but close, was one of the best mods I made.
http://www.vtwingoodies.com/
The brake is a bit harder, since it is frame mounted. You could look for a larger pedal pad though. Even after moving the boards out, I didn't feel like I needed the brake out further though.
Thanks for the reply - I am going to order the extenders from vtwingoodies. If that doesn't help I may change to the ventilator style air. My leg is just not comfortable with the air filter pressed against it and having to turn my foot to brake.
Are there any larger brake pedal out there, that might also help.
Here's one.
http://www.ebay.com/itm/Kuryakyn-445...8feda0&vxp=mtr
