Dyna beads Question
Old 04-19-2015, 07:42 PM
bigblock59's Avatar
bigblock59
bigblock59 is offline
you need to get different valve stem cores. just like the one pictured in the last response. if you go to any car repair shop that does tires, they might have some just laying around. when i do larger truck tires at work i use the beads and they come with the special valve core to be used.
Old 04-19-2015, 08:31 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,922 Likes on 3,022 Posts
Originally Posted by amkaos
I'm not saying liquid nitrogen..the gas and its readily available..
Places charge like 5$/tire but if you go to a public vo-tech mechanics school in your area,
They will do it free..
They have a machine that extracts the nitrogen from the air...works really really well
Sorry, thought you were being a smart ***.
Old 04-19-2015, 09:19 PM
swifty's Avatar
swifty
swifty is online now
When I put dyna beads in my tire the bike was new and I was worried that moisture from the air compressors over time would cause the beads to clump together or get stuck in the valve core. I'm a HVAC tech so I have a tank of nitrogen in my garage. When I did it my friends thought I was nuts. But I have no problems checking my tire pressure.
maybe nitrogen is the way to go????
Old 04-19-2015, 09:39 PM
amkaos's Avatar
amkaos
amkaos is offline
No doubt, it is the way
Old 04-20-2015, 05:17 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
We, I ordered filtered valves. Let's see how this works out.
Old 04-20-2015, 07:23 AM
amkaos's Avatar
amkaos
amkaos is offline
i like those schraeders for sure.. never seen em..
still, check into the nitrogen thing..
Old 04-20-2015, 08:42 AM
Lakerat's Avatar
Lakerat
Lakerat is offline
Little late checking in on this OP, but you are bassackwards when you check the air in your tires with Dynabeads. They should be at 6 o'clock and I like to lightly peck the stem to let gravity do it's job.
Old 04-20-2015, 11:22 AM
UT-rckr's Avatar
UT-rckr
UT-rckr is offline
This^
And there is a reason mines use nitrogen in their haul truck tires.
Old 04-20-2015, 02:35 PM
Jersey Drew's Avatar
Jersey Drew
Jersey Drew is offline
why not just set the valve at the 6 o'clock position and let gravity help you?
Old 04-20-2015, 02:41 PM
SPRINGER's Avatar
SPRINGER
SPRINGER is offline
Received 3,269 Likes on 1,975 Posts
I tried Dyna Beads once and had the same issues. I didn't have any patience with it so I had them taken out and changed over to Ride-On and now I don't have to worry about it anymore.
Quick Reply: Dyna beads Question
