It's been Two years since I "finished"...
Received 3,952 Likes
Thank you on the comments of the paint. I spent a lot of time trying to get the exact colors and decals from my memories in elementary school of watching the bikes ride by on Westminster Blvd.
Re: Breather Bolts-
Up until a decade or so ago, everyone vented crankcase pressure (which is a hot, oily, oxygen depleted air) to the atmosphere.
Then the EPA stepped in and said MFG had to push it back into the engine to be "burned".
Unintended consequences are-
Less power
Less mpg
Carbon build up on pistons and valves (reduced engine life)
All HD's come stock with the crankcase vented into the engine, and most aftermarket air cleaners also vent back into the engine.
The Breather Bolts do NOT vent back into the engine, netting an increase in power, efficiency, and longer engine life.
For those that don't like/want Breather Bolts, there is also a line of Hose & Filter external breathers that keep the engine running strong and clean like the Breather Bolts.
See HERE
Re: Breather Bolts-
Less power
Less mpg
See HERE
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
As a recent entrant into the Softail arena, and forgive me for asking what might seem an obvious thing to most, but could someone enlighten me as the differences between a Heritage and a Deluxe please?
I have an '06 Deluxe, and other than some minor trim differences, they seems virtually identical.
I did change to the Deluxe turn signals in the back, and wish I had in the front...still something I "need" to get done.
super77ta
06-13-2015 06:16 AM
