replacing the starter
1988 has the 4 speed type starter with the separate solenoid...the easy way would have been to unbolt the starter from the gear housing...and leave it undisturbed. Getting the gear housing lined back up "by feel" without being able see what you are doing will be difficult to say the least...I have seen people break the housing trying. If you can't bolt the gear housing back up...the easiest way is to remove the outer primary...install the gear housing first ...then install the starter drive second.
Jackie Paper
12-15-2011 01:16 PM
