Valve Guide cracked after 14k Miles. What gives?
Old 04-28-2015, 07:44 PM
2009FLSTSB's Avatar
2009FLSTSB
2009FLSTSB is offline
Default Valve Guide cracked after 14k Miles. What gives?
So on my 2009 Xbones I did an engine upgrade, cams and headwork at approximately 15,000 miles. Everything ran great up until about 2 weeks ago with 14,000 miles on the new engine. I lost compression in the front cylinder and after pulling the head, the exhaust valve wasn't seated in the combusion chamber. I took it to an indy that is known for his head work and we took it apart. The exhaust valve was bent with quite a lot of carbon and oil built up around it. After he pulled the valve guides, the exhaust valve guide was cracked. He's thinking the valve seal let oil seep into the valve guide and it was basically cooked inside the valve guide causing the valve to stick and impact the piston, bending the valve. I've never messed with rebuilding heads so I guess I'm asking what would cause the seals and / or guides to fail with only 14k miles on them?
timrvv1
Engine Mechanical Topics
08-11-2017 06:53 AM
lagunatic
Shovelhead
03-07-2014 11:40 PM
terrapin88
EVO
05-09-2013 10:33 PM
Stng72
09-06-2010 09:53 PM
Reffixer
Exhaust System Topics
01-10-2006 01:22 PM
Quick Reply: Valve Guide cracked after 14k Miles. What gives?
