Slim Fuel Mileage Tips.
Old 04-29-2015, 06:02 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Default Slim Fuel Mileage Tips.
So I know I'll figure out my bikes habits after a while, but what are the fuel mileage particulars on your bike??
For example, the fuel indicator comes on with a supposed one gallon left. When the light came on today, the gauge was dead on E; way into the red. The Remainder said 28 miles though; this I found weird?! Shouldn't the mileage be a little higher? What's that based on?
I went to the gas station, the R said 26 miles left, and it took 3.8 gallons to fill it to the bottom of the neck. Clearly I had more than 26 miles left with 1.2 gallon (supposed) in the tank.
Just curious what you guys see.
Old 04-30-2015, 05:53 AM
WKNDS's Avatar
WKNDS
WKNDS is offline
Received 1,263 Likes on 931 Posts
IMHO the guage in the cap is pretty conservative. I compare it to the
range-estimate on my Speedo-Tach combo guage and the digital guage
is always higher. I have never gotten down to the low-fuel light since
I always ride with the OL & she has a sportster so has to stop for
fuel alot sooner than I do....
T.
Old 05-05-2015, 08:29 AM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Second tank....ran it down until the low fuel light came on (gauge was way down on E) and my gauge swapped over to the Range screen. I ran it until the Range indicator showed 10 miles left. I went and got gas and took 4.1 gallons to fill to the bottom of the neck. I had close to a whole gallon left...that's a bit more than 10 miles of range left. Still learning my bikes characteristics obviously, but I guess these indications are conservative and just enough to give you some situational awareness.
Old 05-05-2015, 08:41 AM
jam436's Avatar
jam436
jam436 is offline
The H-D analog speedo (p/n 74774-11 - Combination Analog Speedometer/Tachometer, 5" - Spun Aluminum Dial) is far more accurate than the stock gauge.
When the tank gauge said "E", the new analog gauge correctly shows a 1/4 tank.
And after the tune with a Vance & Hines FuelPak3 I'm getting a steady 40MPG in the city, 45MPG highway.
Old 05-05-2015, 09:27 AM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
T.
I have to echo your comments. With wife on her sportster I never go past 120 miles.
On my bike none of the 3 fuel indicators are correct. Last time I logged fuel usage I had gone 197 miles and filled up with 4.6 gallons. This was about 25 miles past both gauges saying E and the DTE warning.
soldierboy
06-08-2017 07:08 AM
Jenks507
08-21-2015 03:49 PM
roadchaser
05-19-2013 07:15 PM
coconl
08-11-2011 10:14 PM
TexasJR
03-10-2011 08:46 PM
Quick Reply: Slim Fuel Mileage Tips.
