What do you think? $1,000 for SE Pro Super Tuner and complete dyno
Here is a question for those of you more knowledgeable on dynos and tuning. Do you have to have a tuner to get a dyno? Can a dyno communicate directly to the ECM or does there have to be a device in between to communicate?
My friend swears his dyno guy yanked his PCV out and dynoed his 2009 SG with no tuner. He took four hours to dyno it and when he had the perfect tune he saved it to a USB flash drive and my friend carries that around on his key chain in case he ever has to go to a HD dealer in a pinch when he is away from home.
That is where I'm confused. If you don't need a tuner to get a dyno performed, why spend the extra money and have another piece of equipment on your bike that can fail?
Actually it sounds like the OP has a 103" twin cam with a Stage 1 heavy breather and VH Big radius pipes.
He should buy the Race Tuner (or TTS tuner) and go to the Fuel Injection section of the forum and ask if someone has a map.
This is exactly what I did and some very generous forum members sent me maps from their stage 1 dyno tune. Their setups were practically identical to mine. I then used the tuning feature of the SESPT to dial in the map even further. Bike runs awesome!
Peg20, you are right about the dyno guy having a flash tuner. I spoke with him the other day. He uses Direct Link by TechnoResearch. He charges $250 for the tuner and $300 for the dyno, which takes about 4 hours. This is half of what the stealership wants for the HD flash tuner and dyno.
End result for $550 is you get a perfectly tuned bike and your map sent to you electronically and on a USB drive that you can carry on your key chain.
My friend who uses this guy did not realize he was using a flash tuner. He just knew the dyno guy pulled his PCV and said he could do a better job without it.
The price is high.
I've had two SEPST on the last two Dynas I owned. I downloaded a base map and tuned both bikes myself and a friend's as well. There is a good thread in the forum about the SEPST and tuning with them. Go to "Harley Davidson Tech & Mechanical" section and then "Ignition/Tuner/ECM/Fuel Injection." There are a lot of good tuning devises out there. For my 06 Softail I will probably try a Thundermax. Fuel Moto, from what I have read using the advanced search engine in the forums, seems to have a good support system and are very helpful.
