Bags on a Deuce
Bags on a Deuce
Hi all,
I've looked through many of the threads in the Softail forum but didn't see any on hanging bags on a Deuce.
I have a 2007 and really enjoy my ride to work now!
I've talked with the parts guy at the dealership that put on my floorboards and he looked in his 2007 catalog. The support brackets had a "Z" bend, mounted on the inside of the fender, bends to bring it horizontally around the fender edge, and then down to support the bag.
Does anyone make these brackets anymore? How did you Deuce Baggers get them mounted on?
Here's my Deuce:
Astra
Thanks!
MikeJ in San Diego, CA
Here's my Deuce:
Astra
Thanks!
Mine are factory. Here's a few shots of the hardware. I left off but hung the additional pipe support on the garage wall that attached from the back and ran back, turned 90 degrees under the tail light and back and to the other side. The d rings are from the seat and not hanging the bags. There is also another u-plate brace under the fender that that metal plate that the bag attaches to bolts too. That plate limits you to a stock tire for sure. You also need the relocation kit to kick the signal lights back. The original are straight out looking. The relocation ones are angled back. I run OEM pipes off a Custom. Your stock Deuce/Fatboy pipes almost limit you to the OEM style bags. Even mine are close but one of these day, I plan on dropping mine down even under the chrome fender brace. Ebay has a lot of stuff and some OEM ones. Older OEM will probably be wrinkled like mine. I do not take care of them but grunge is me..there leather and I am a slave no on one or thing.
