FXSB Breakout – Custom Paint & more Chrome
Old 06-18-2015, 01:34 PM
EagleRay's Avatar
EagleRay
EagleRay is offline
Default FXSB Breakout – Custom Paint & more Chrome
Hi guys!
Like only two months ago my pal Nostradamus74, I finally managed to get my Breakout project "almost" finished. "Almost" 'cause you all know „never say never“ and actually I already know what comes next although the recent mods session has just been closed
Only yesterday I picked up the bike from the dealership where the latest parts have been installed. This project started quite some time before I even got the bike in March 2014. First mods were planned and parts ordered already before I even ordered the bike . Now, after more than one year the project has come to its first major milestone.
I wish to thank all of you who have been of great inspiration, help and support during the last months. Without all the awesome support and knowledge sharing from/with you guys here on HDF this project would never have come this far. My special thanks to Nostradamus74 for constantly challenging me and my ideas, as well as my wallet, and to Pigbacon for his outstanding support to make this project reality.
Main modification and the real customization is the new paint job a local airbrush guy realized for me. Main aspect for me was to maintain the basic black (and chrome) character of the original bike but to add some color together with something truly individual. Doing some research on the world wide web I found different paint schemes and patterns of which I chose several different examples and gave them to my airbrush guy as a basic idea. After explaining to him what I was after I just let him do his creative work.
Referring to my actual first name that derives from the Norse Mythology and means „Thor's Hammer“ (Mjolnir) I wanted this to be rendered by the paint job, too. The symbol on the rear fender represents Thor's Hammer and is therefore somehow the name tag of the bike...
In addition to the new paint those were the parts installed during the last mods session:
  • CVO Chromed Turbine Rims (and spacers)
  • Turbine sprocket
  • Teardrop rotors
  • Metzeler 260/40-18 Rear Tire
  • Metzeler 120/70-21 Front Tire
  • Diamond Back Throttle Cables
  • Diamond Back Front Brake Lines
  • Chrome ABS Harness Cover and Banjo Bolt Covers
  • Chrome Brake Caliper Inserts
  • Chromed Lower Belt Guard
  • Chromed Front Axle Nut Covers
  • Chrome Braided EFI Fuel Line
  • Chrome Braided Fuel Crossover Line
  • Polyurethane Riser Bushings
  • Chrome Ventilator A/C Cover
  • SE High Flow Oil Pump
  • SE Perfect Fit Pushrods
  • SE 204 Cams
  • SE Inner Cam Bearings
  • SE Heavy Duty Clutch Spring
  • Billet Clutch Cable Adjuster
  • Chrome Front Brake and Clutch Levers
  • Chrome Slotted Shifter Rod B&S
During the next weeks I will try to complete this list with the mods done before and where possible add the part numbers at least for the HD OEM parts used. >> Edit: I managed to complete the list of parts used for the build (w/ P/N). You can find it at the end of this post...
As for now I am still running the canned map. Bike is going to be dynoed as soon as possible.
HD OEM Parts
Slipstream Grips - 56100028
Slipstream Passenger Pegs - 50500091
Slipstream Footpegs - 50500091
Slipstream Brake Pad - 50600037
Slipstream Shifter Peg - 33600008
Custom Mirrors Slotted Stem Profile - 91697-06A
Flush Mount Gas Cap - 61100006A
Screamin' Eagle Vent. Perf. A/C - 29490-09
Screamin' Eagle Pro Super Tuner - 32109-08C
Screamin' Eagle 204 Cam Kit - 25464-06
Cam Service/Install Kit - 17045-99D
Screamin' Eagle Perfect Fit Pushrods - 18400-03
Screamin' Eagle Heavy Duty Clutch Spring - 37951-98
Screamin' Eagle Inner Cam Bearings - 24018-10
Screamin' Eagle High-Volume Oil Pump - 62400001
Drive Gear Retention Kit - 25566-06
Chrome Inner Primary Cover - 60815-08A
Transmission Sprocket 30T (Front Pulley) - 83595-11
Billet Shifter Lever, chrome - 34539-00
Billet Rear Brake Lever, chrome - 42632-07
Shift Linkage slotted, chrome - 33760-09
Rear Master Cylinder Cover, chrome - 46425-05A
Master Cylinder Cover, chrome - 46424-05B
Stock Dragbar Handle Bars - chromed by SportChrome - 55800215
(Stock) Chrome Oil Tank - chromed by a local company
Clutch Bracket and Master Cylinder Reservoir Kit - 45355-08
Chrome Switch Housing Kit - 71826-11
Chrome Switch Cap Kit - 71500110
Switch Housing Hardware Kit - 91124-03A
Fork Slider Assembly left (CVO), chrome - 45500148
Fork Slider (FXCW, FXCWC), chrome (only right side used) - 46951-08
Chrome Rear Caliper Bracket - 42048-08
Diamond Back Thrittle/Idle Cables - 38781-06
Diamond Back Upper Brake Line - 41800053A
Diamond Back Lower Brake Line - 41800308
Diamond Back Clutch Cable - 38849-09
Billet Clutch Cable Adjuster - 64108-03
Braided Stainl. Steel Fuel Crossover Line - 63692-00A
Braided Stainl. Steel EFI Fuel Line - 63020-04
Hand Control Levers, chrome - 45075-07
Polyurethane Riser Bushings - 56165-03
Turbine Cust. 18 in. Rear Wheel, chrome - 40900057
Turbine Cust.21 in. Front Wheel, chrome - 43300047
CVO Front Wheel Spacer - 43300199
CVO Cover Wheel Speed Sensor - 42106-11
CVO Rear Wheel Spacer - 41841-08
Teardrop Front Brake Rotor - 44367-00A
Teardrop Rear Brake Rotor - 44368-00A
Turbine Billet Sprocket - 42200007
Chrome Sprocket Bolts - 94773-07
Lower Belt Guard, chrome - 60654-07A
Oil Dipstick Digital - 63002-09
Combo Speedo/Tach 4'' - 70900100B
Blackline Tank Console - 71340-11
Moulding Rubber 2x - 71576-08A
Trim Insert - 72775-11
Top Plate - 60900001
5 3/4 '' Bullet Headlamp - 68593-06
Mounting Kit Bullet Headlamp - 69611-06
Chrome Gauge Visor Ring 4'' - 74662-04
Voltage Regulator Cover, chrome - 74597-01 > removed for chin spoiler install
Tapered Front Axle Nut Covers - 43051-01
Rear Axle Cover (only right side) - 44345-09
Pivot Bolt Cover (only left side) - 47612-08
Frame Inserts, chrome - 48212-08
Headbolt Cover Kit, Finns - 43859-00
Banjo Bolt Covers, chrome - 32715-98
Chrome Riser Hardware - 63026-05
ABS Harness Cover - 32700002
HD Brake Caliper Inserts, chrome - 44477-99
Aftermarket Parts & Accessories
Custom Paint Set MJOLNIR (Tank/Console/Fenders)
Custom Chin Spoiler Thunderbike "Crossfire" with paint theme MJOLNIR
Custom Solo Seat "Diamond Stitching“
Custom Derby Cover - Engraving: Mjolnir (Thor's Hammer)
Custom Timing Cover - Engraving: Mjolnir (Thor's Hammer)
Metzeler Rear Tire ME 880 260/40-18
Metzeler Front Tire 120/70-21
KessTech 3'' ESM2 Big Slash
HD Front Brake Caliper (aftermarket chroming)
HD Rear Brake Caliper (aftermarket chroming)
Technicad Coil Cover, chrome
Chrome Braided Spark Plug Wires
Thunderbike Flat Risers, chrome (with 1.2 in chromed riser spacers)
Custom Axle Mount License Plate Holder
Kellermann 3-in-1 LED Rear/Turn Signals, chrome
Kellermann LED Front Turn Signals, chrome
Progressive Suspension 422 Series - 422-4037C
Progressive Suspension Fork Spring Kit (Standard) - 11-1525
Arlen Ness 3'' Fwd. Control Extension - 26-2413
Rarebag Custom Swingarm Bag
Rarebag Custom Fork Tool Bag
Information (P/N) supplied w/o liability
Missexeccph (11-23-2016)
Old 06-18-2015, 02:00 PM
Pigbacon's Avatar
Pigbacon
Pigbacon is offline
That is a truly amazing piece of artwork. I love the detail of the paint. It blends well with the bike.there is even some type of marbling in the red and gray paint.
Your bike is amazing Eagle. Congrats.
Old 06-18-2015, 03:20 PM
Dalt10's Avatar
Dalt10
Dalt10 is offline
Very nice looking bike. How did you extend your foot controls? did you use HD parts or after market?
(edit) I see the answer in your signature.
Old 06-18-2015, 03:57 PM
jgos929's Avatar
jgos929
jgos929 is offline
Looks great
Old 06-18-2015, 06:56 PM
Alain's Avatar
Alain
Alain is offline
The paint is phenomenal man!! Nice bike !!!
Hdbreakout84 (08-29-2023)
Old 06-18-2015, 07:07 PM
cdonis's Avatar
cdonis
cdonis is offline
I glaced at this thread earlier today and didn't get it. Now I really took a good look at it and you hit a home run my friend. Very Very Nice.
Old 06-18-2015, 08:04 PM
red deuce's Avatar
red deuce
red deuce is offline
The pipes and rims look killer
Old 06-18-2015, 08:23 PM
Stone Cliff's Avatar
Stone Cliff
Stone Cliff is offline
Wow.. Great job!!!
Old 06-19-2015, 02:54 AM
Nostradamus74's Avatar
Nostradamus74
Nostradamus74 is offline
Happy and proud to have been involved in all the project, dude. Following the various phases of your project as you followed mine has been a great pleasure and fun. Our BO have dozens of parts in common but at the same time they're so different. Sharing ideas, trimming our choices, comparing our different approach and studying together has been a great experience and we both know it's not ended yet...if ever will end...
Mjolnir turned out really AWESOME, for sure a true head turner...
A few more details to trim in the future and she'll be done...pardon, "almost done"!
Old 06-19-2015, 12:11 PM
EagleRay's Avatar
EagleRay
EagleRay is offline
Originally Posted by jgos929
Looks great
Originally Posted by Stone Cliff
Wow.. Great job!!!
Thx guys! I really appreciate your feedback as it confirms I am not the only one who likes it .
Quick Reply: FXSB Breakout – Custom Paint & more Chrome
