Da-Rza 2015 breakout build
#41
did alittle more today for the time i had left after riding mx for 7-8 hrs...was kinda beat but ended up installing shotgun shock and fitted the trask vline bars/speedo clamp that was pc...and of course scotch brite the chrome ring!!!now i have to attend to my new little friend/monster and also installed clutch cover that was pc as well
theats an very good bars!
Can you say me whats that for a bars?
regards
Street
#42
mgardner4623 (09-11-2017)
#46
thanks guys!...future mods will be blacked out lyndall rotors,custom hyperpro steering dampner/top mount like sportbike and yes different size pulley in black as well as pc the wheels,just want to ride it since the weather is cooling down in the desert...
#47
alittle more done tonite,added exhaust and ran wiring for powervision/usb/cig lighter port to front of the bike,the aluminum frame im making for arlen ness fairing will also be a bracket for mounting pv and usb ports gonna add oil and start tomorrow hopefully no leaks...also made these 57-60 c-10 truck center caps work on a aftermarket steel smoothie wheel..had to tig weld a smaller ring to the bigger center caps worked like a charm,now off to get powdercoated translucent copper with pearl white center caps then doing baby blue/red highlights in center caps,and wrapped in toyo wide whites,like the way my truck build is looking so far
#48
#50
ive hit some pot holes out here at high speed and got some wobbles in the front end and a top end dampner would really benefit to keep it alittle more steady...i have had numerous custom harleys with dampners and they worked great for that,but of course your right on tank slappers,you would never push this bikes front end that hard to get that..i get enough of those racing at buttonwillow
