I'll start by saying that I like to be a bit different... So what I did was
gut a "vintage" HD horn and put a smaller sportster style horn I got
from DK Cusoms in the case. Then I mounted it up front. Here's a pic.
Any pics of this set up? Where did you find horns that fit? I like the idea of a de-cluttering the bike.
No pics. One horn is the stock horn the other is same size as stock from Amazon. They just fit pointing down. For brackets I used galvanized simpson tie from home depot. Easy to bend, drill, wont rust and no one will see it. Plenty loud also!
Thanks
I'm sure I can figure out something. Wife just gets impatient when I'm with "her".
I made a little bracket to attach it to an unused tapped hole behind the clutch cover. Took a couple tries but I made it work. The attached pic was my aluminum prototype bracket for test fitting. I remade it with steel for my permanent install.
