Intalled DK Customs drop in LED bulb in my Slim
#62
I thank DK for researching these and selling us ones that they have spent the time and money to vet. I've bought too much cheap junk on eBay and wasted my money. Wish I'd seen these back when I made my LED decision because my LED is hard to see during the day.
Plus I like to support a small businessman trying to put food on his table.
I'd like to see some comparative shots at night....
#63
Received 3,940 Likes
We warranty them for one year. If it stops working, simply return it to us and we will replace it at no charge.
See HERE
Thank you!
Here are some comps at night, you can right click on them to make them bigger.
See HERE
#64
#65
Anyone?
Does the LED bulb require the metal dome in the headlight housing?
Curious....do you need the stock glass housing for the LED bulb? I have a HELLA (EURO non-DOT) glass housing that gives better light spread. The HELLA does not have the little metal dome in it. What is the purpose of the dome anyway...it's a dull corroded color on the inside.
#66
In changing the lens and the bulb, the metal dome may or may not be beneficial, the only way to know is to test it. We have not tested without it on the Softail (and we have only used the stock lens.
We have tested on several other headlights that do not have the dome, and it works just fine.
While it is not mechanically necessary for the dome to be installed with the DK LED, the only way to know if it is beneficial with your non-stock lens is to look at the beam at night, with and without it.
#67
Received 2,189 Likes
B2136 Low Beam Output Open
B2137 Low Beam Output Shorted High
#68
#69
For those that have the Dual Bulb Headlights, we now have LED Drop-in Bulbs for those also. You can see the details HERE.
