Exhaust leak?
Old 08-05-2015, 12:12 PM
Jersey Drew's Avatar
Jersey Drew
Jersey Drew is online now
Default Exhaust leak?
Will an exhaust leak cause a CEL? My bike sounds like it possibly has an exhaust leak but do not know how to confirm. No CEL either.
Old 08-05-2015, 12:44 PM
Jersey Drew
Just got the bike home and looked. I found both nuts on front exhaust flange were loose. So I have to let it cool and re tighten them later hopefully ther reseal with the gasket.
Old 08-06-2015, 05:11 AM
olongapo1's Avatar
olongapo1
olongapo1 is offline
My 2 cents. I personally would loosen all the nuts and bolts on the entire exhaust, then torque starting at the flanges working rearward. Doing so provides a little play / movement allowing the header pipes to seat into the exhaust ports.
Old 08-06-2015, 06:10 AM
harty's Avatar
harty
harty is offline
When I had my brand new bike with new pipes delivered from the dealer it was popping loads and didn't sound right. I confirmed exhaust flange leaks by using a BBQ lighter/flame and running it around the exhaust flange gasket area with the bike running. If the flame moves at all you have a leak. Just make sure you do it where there is no wind at all. Mine would blow the flame out it was that bad.
I Discovered they put the wrong gaskets in and they were not crushed.
The flame should look smooth and lick around the pipe.
Cheers
Harty.
Old 08-06-2015, 10:12 AM
Jersey Drew
they tightened right back up and all the extra sound is now gone...
Old 08-06-2015, 04:42 PM
Strahley's Avatar
Strahley
Strahley is offline
If they do that again, you may want to put some lock washers on them
brad75raiders
EVO
05-26-2018 01:06 AM
GalvTexGuy
Exhaust System Topics
01-30-2016 11:17 AM
Tucker99
07-07-2014 02:05 PM
timberwolfz28
08-31-2008 11:44 AM
kawsakimx6
02-09-2008 03:50 PM
Quick Reply: Exhaust leak?
