Softail backfiring
Old 08-16-2015, 05:00 PM
Abigail1's Avatar
Abigail1
Abigail1 is offline
Stage II
Default Softail backfiring
i have a 2006 Softail deluxe. Drove it to work the other day on the way home it started backfiring sputtering and stalling out. I made it home what's going on? I have 25,000 miles on it.
Old 08-16-2015, 05:02 PM
chief08's Avatar
chief08
chief08 is online now
check fuel pressure
Old 08-16-2015, 05:05 PM
Abigail1's Avatar
Abigail1
Abigail1 is offline
Stage II
Thanks for the tip
Old 08-16-2015, 05:40 PM
HDmikie's Avatar
HDmikie
HDmikie is offline
My 02 EFI Fatboy did same about a year ago. It was the fuel line inside the tank. For some reason little holes appear and air gets sucked in instead of fuel. Have them replace the filter while in there.
Old 10-02-2015, 10:43 PM
Firemed80's Avatar
Firemed80
Firemed80 is offline
Got a question, did you find this out or did you take it in? I'm having a issue with my 02 Springer. She's been hard to start the last couple of weeks and tonight at highway speeds she'd dog out here and there. I was thinking that I had gotten some crappy fuel because of the hard starts. But now with the ******* out I was leaning towards a possible filter issue. Now reading what you had, thinking its along the same lines.
Thanks!
Old 10-02-2015, 10:46 PM
QC's Avatar
QC
QC is offline
Received 19,784 Likes on 9,863 Posts
Thanks!
It's a relatively common thing to happen.
Old 10-03-2015, 05:32 AM
HDmikie's Avatar
HDmikie
HDmikie is offline
Thanks!
If your bike is EFI it's very likely the same issue I had. I took my bike to the local Indy shop and had Adam do the fix. He charged me $209 and haven't had a problem since.
Old 10-03-2015, 11:56 AM
Firemed80's Avatar
Firemed80
Thanks for the input. Looks like I got a little Sunday project figured out for me. Ill open it up and take a peak.
Old 10-05-2015, 10:21 AM
oct1949's Avatar
oct1949
oct1949 is offline
Ditto..... mine had the hole in the gas line at 33K miles 3yrs ago..
Fill up your tank and see if the missing stops. if it does then you have the pin hole somewhere
My bike would go about 90 or so miles before it'd start missing out on a full tank.. fill it up and all was fine for another 90 or so..
Start with the easy stuff first before going into Elec. issues...
Old 10-05-2015, 03:18 PM
Freak Show's Avatar
Freak Show
Freak Show is offline
had that problem with my dyna. I was putting 91 octane in my tank. my buddy who owns a shop told me to run 89. he said because most people don't buy the high octane and because of that it sits in the tanks longer and breaks down. gas only has a two week shelf life with the ethanol. after I switched back the problem went away.
YammyBase
03-05-2018 07:23 PM
Longshot USMC
07-24-2014 10:25 PM
DMetcalf
05-17-2014 07:47 PM
Whiskyjock
01-26-2014 09:58 AM
Zacfatboy
04-12-2011 03:39 PM
Quick Reply: Softail backfiring
