SE 110 kit for 96 no case maching required
#33
Ok so just off phone w HD buddy whp knows all. It's just a 96 sleeve bored to 110, simple as that. Super thin walls we can assume most builders would agree. I'm wondering how reliable this could be in maxed out tq/hp situation? Maybe a high volume oil pump and upgraded piston cooling jets would add reliability? Either way, who's going to be the guinea pig?
#35
CVO 110 cyl are different and CVO cases are larger so 113 on a CVO 110 sleeve is not as thin as the 96/103 - 110 bore. The only reason the new 110 barrel is safe in a 96/103 case is the new steel construction.
#36
I believe what HD is offering here is a factory upgrade that has a warranty, and EPA blessing.
You should be able to go to the aftermarket and get something that would perform even better, but would not be street legal or have a factory warranty.
Nice to have choices.
Expect there will be a bit more heat with this upgrade, but predict it will be a smooth running, strong pulling motor.
#39
