Performance: Beakout high output engine vs slim s 110?
Old 09-09-2015, 02:18 PM
RexD's Avatar
RexD
RexD is offline
Default Performance: Beakout high output engine vs slim s 110?
What is the benefit of the high output engine on the new Breakout?
How would the performance of the 2016 breakout be compared to the 110 slim s engine?
Thanks
Rex
Old 09-09-2015, 02:38 PM
USAFANGWINGNUT67's Avatar
USAFANGWINGNUT67
USAFANGWINGNUT67 is offline
From what I just read on HD site is about 3 Foot Lbs of Torque in favor of Slim.
But HD site they both have the 103 motor.
Per '16 models specs comparison.
http://www.harley-davidson.com/conte...are-bikes.html
STOP THE PRESS............correction:
Looks like 11.6 in favor of 110 motor. Sounds like a noticeable difference.
Old 09-09-2015, 04:54 PM
jgos929's Avatar
jgos929
jgos929 is offline
Screw the 110. Whats the difference between the 103 and the HO103?
Old 09-09-2015, 06:19 PM
SLV's Avatar
SLV
SLV is offline
Lighter pistons, cams, high-flow air cleaner. But that's just what's listed in the marketing.
Old 09-09-2015, 06:47 PM
SLV's Avatar
SLV
SLV is offline
The parts list shows 25400002/25400003 cams in the Breakout. These are the same as the 2014 and 2015 touring models. Because they are "stick" HD part numbers, there isn't much information about the grind. The Breakout's peak torque is at 3000 RPM.
SE255 cams are in the SE110 in the new Slim S, and peak torque is at 3500 RPM. This motor has other SE parts too.
It's possible that the HO103 produces power better at higher revs (not necessarily more overall, but a longer curve), but HD doesn't publish the HP numbers that I know of, only torque.
jswatzell
11-08-2016 01:50 PM
artsbest
04-08-2016 07:19 PM
bubba455
Exhaust System Topics
72
03-18-2015 09:56 AM
Jdartfordct
02-27-2008 12:57 PM
witch1
01-21-2006 10:52 PM
Quick Reply: Performance: Beakout high output engine vs slim s 110?
