Loss of MPG
When I had air cleaner and pipes fitted to my fatboy, and the dealer download, the mpg was terrible, and not too different from your numbers.
I then smart-tuned the bike (FP3 has a similar feature; earlier fuelpaks are junk). This improved the mpg massively, to better than stock. I then continued fiddling to improve performance at high throttle or high rpm settings. I got massive performance improvements and the better mpg to match. And it doesn't matter how heavy I get with the throttle, I still get great mpg.
If you've got one of the earlier FuelPaks, then you've been robbed. Get the FP3, or a TTS or a DynoJet PowerVision. (I have the SEPST but don't recommend it -- the others I mention will do just as good a job but much more user friendly.)
Yup, I didn't believe you could have more power AND more mpg, but I got both. Believe what you want to believe, Warp Factor. It makes no difference to me.
Received 14,147 Likes
Originally Posted by ednigma
I just picked up an 2005 Softail. 88in injected. It is getting 26 mpg. to me that is obnoxiously low.
Maybe something is wrong and something is reading in meters? Either that or somebody swapped out the speedometer drive or speedometer and it is causing your odometer to read half of what it should.
How about a fuel look leak?
No kidding. With that mpg, you must ride from gas station to gas station.
No leaks. The hop I got the bike from is not at the top of my list of good shops. I need to have the set up looked at. I think the previous owner put on the Python 2 into 1 pipe and didn't have the bike tuned to work with it. Plus the python is wide open. No Baffle.
If it would be dumping that much fuel, it seems like it would run bad or have a gas smell in the exhaust.
How many miles do you get out of a tank of gas?
