Calling all Shotgun Shock installers:
Then I used the jack (with a small piece of plywood) to move the rear wheel up and down.
You need to move the wheel up pretty far in order to get the stock shocks out, since the front bolts don't come out of the shock.
Then I would move the wheel back down (with a helper) as I guided the Shotgun into place in the front in order to get those bolts in...
I have to correct myself: the service manual calls for blue Locktite. Not sure what Harley used at the factory, but I'm betting getting those bolts out will be a lot easier this time than it was the first. Maybe I'm just hoping that...
I think he's talking about the rubber bump stop at the top of the frame where the swing arm would contact the frame in the event of bottoming out.
If you remove it, your bike will sit lower when slammed (with air dumped from shock). Some guys even resort to grinding down the frame at that point to acheive an uber-slammed look.
The drawback is that if you ever bottom out while riding, it doesn't feel good (or sound good). Your drive belt may also contact the casing where it feeds out of the primary and your swingarm may contact the oilbag, as well.
I removed it and the only problem I've had is that painful feeling on bottom-out. That doesn't necessarily hurt anything (but the rider), but it's good to check all points for clearance if you decide to remove it...
I remain firm on my stance that individual shop discounts (especially those of forum sponsors) should not be discussed here, if not published by them. What discount they give is for them to decide, not forum members. If JD has ever mentioned a standard for members discount publicly on these forums, then I will of course stand corrected. But to my knowledge he has not...
A quick search turned up this example:
https://www.hdforums.com/forum/softa...l#post11678110
My only problem during install was over tightening the compressor motor clamp. DO NOT OVER TIGHTEN THIS. It puts drag on the motor and causes the fuse to blow. It just needs to be snug. I found out about this problem at 10 pm and no spare fuse. Other than that its pretty straight forward. I also bought a Liquivac oil vacume pump to make trans fluid changes easier. The SS needs to be dropped on the front to get to the trans drain plug. I use the vac to suck out the warm trans fluid. I change fluid everytime I change oil. I do drop the SS and pull the drain plug about every fourth oil change.
