Calling all Shotgun Shock installers:
I remain firm on my stance that individual shop discounts (especially those of forum sponsors) should not be discussed here, if not published by them. What discount they give is for them to decide, not forum members. If JD has ever mentioned a standard for members discount publicly on these forums, then I will of course stand corrected. But to my knowledge he has not...
My only problem during install was over tightening the compressor motor clamp. DO NOT OVER TIGHTEN THIS. It puts drag on the motor and causes the fuse to blow. It just needs to be snug. I found out about this problem at 10 pm and no spare fuse. Other than that its pretty straight forward. I also bought a Liquivac oil vacume pump to make trans fluid changes easier. The SS needs to be dropped on the front to get to the trans drain plug. I use the vac to suck out the warm trans fluid. I change fluid everytime I change oil. I do drop the SS and pull the drain plug about every fourth oil change.
I'd like to get them a technical writer to tighten up their instructions a bit. When I didn't own a torque wrench, I always hated when they mentioned torque numbers. Now that I own 3, I hate when they don't tell you exactly what to torque it to. I'm hoping that when I get started, the instruction will make more sense. The pictures in their instructions may as well be upside down for all the help they've given me.
I think once you have the system, try the compressor on for size up in that void behind the transmission and can see everything in context with your bike, it will all become clear.
I need to pull my whole system and replace it this weekend. If you want, I'll try and take some better pictures for you to show how it all fits together...
You called? LOL
Actually, after a quick search, I found THIS.
Let me know if you need any clarification after going though it...
steelerdude1
11-27-2013 08:05 AM
