My Mods Thread - 2016 Softail Slim S
Old 10-05-2015, 12:53 PM
wachuko's Avatar
wachuko
wachuko is offline
Thumbs up
Originally Posted by SLV
I personally like the look of the stock exhaust...
I probably did not articulate my thoughts correctly.... that is what I meant to say. I have not found anything aftermarket that looks or goes with the looks of the bike, like the stock exhaust does...
Old 10-05-2015, 12:58 PM
Sticks24's Avatar
Sticks24
Sticks24 is offline
Coin looks great! Not sure about the wheel mod. Might hurt the old school look of the bike. Will have to wait and see. Wheels would probably work better on the black bike.
Old 10-05-2015, 12:59 PM
goblue90's Avatar
goblue90
goblue90 is online now
Wachuko and SLV, the 3 of us had extensively modified Sportsters. Though it sounds like we're all in agreement that nothing really has to be changed on our SlimS, I'm curious to see who's going to get the mod-bug and start radically changing his bike first... it's not going to be me!
Old 10-05-2015, 01:10 PM
wachuko's Avatar
wachuko
wachuko is offline
LOL... true... not going to be me either... (can't believe I just typed that! )
On the Sportster, I wanted tubeless wheel/tires combo just for the peace of mind... since I am taking them off the Sportster, I figured I would try them on the Slim to see how it looks. Outside of removing the rear tire from the wheel, to turn it around, there is really not much to it... well, now that I think of it, need to check the inner diameter of the bearings in the front... worse case scenario, I will have to get new bearing in the front if it is not 25mm in the Slim...
Oh, and in my case, it replaced both the RK CVO and the 48...
Old 10-05-2015, 11:31 PM
wachuko's Avatar
wachuko
wachuko is offline
Baby steps.. installing what I have...
These tend to break when you least expected... so changing to one with heim joints.
Once the stock unit is remove, install cover with spacer in between cover and lever
A little bit of blue loctite on all bolts... install the linkage. Some blue loctite also on the threaded rod, tighten the nut against the center piece and you are done...
I also removed the rear shift lever... hate it as it is always getting in the way with my boots... nice billet styled, in black, shift lever is coming, but this will do for now.
As I mentioned earlier... today was all about removing the stuff from my Sportster so that I can take it to the dealer in the morning... that is done and now I can spend some time installing the few things I have for the Slim S... good night!
Old 10-06-2015, 04:37 AM
SLV's Avatar
SLV
SLV is offline
It won't be me, not for a while anyway. I spent a lot of money making the cafe sportster only to have engine problems in the second motor caused by the problems on the first. More money was needed to make it right and I had lost the desire.
So, not only does the Slim S need few mods, my wallet needs a break too. Springtime might be another story.
Old 10-06-2015, 07:41 AM
wachuko's Avatar
wachuko
wachuko is offline
Cool
Installed the luggage rack supports...
I had the black covers from the rack supports of the Sportster 48 and those from the Road King... RK covers works great in the front as it covers everything...where the covers from the 48 only cover the plastic portion, leaving the chrome section visible... so using RK covers in the front and the 48 covers for the back.
On the rear mount, for the black covers, I will need to make a notch on the cover so that it goes in all the way. The rear lights are too close to the mount to let the cap go in all the way.
I am going to hold off on making any changes to the cover until the solo rack comes in. Looking at the photo in the HD catalog, they are using a different turn signal base and look at how close that rack mount is
Any modification, I will make it to the rack... I like the looks of the existing turn signals.
And also installed the front bag that I had on the 48... that is all for now.
Old 10-06-2015, 08:01 AM
Freak Show's Avatar
Freak Show
Freak Show is offline
watching
Old 10-06-2015, 09:50 AM
goblue90's Avatar
goblue90
Looking good! I really like that shift lever and storage rack.
Old 10-06-2015, 10:01 AM
FFeric's Avatar
FFeric
FFeric is offline
Looking good. I wasn't aware that part of the shifter tends to break. Good to know.
Quick Reply: My Mods Thread - 2016 Softail Slim S
