I want to change the two things I don't like on my Slim
Old 10-06-2015, 10:43 PM
FFeric's Avatar
FFeric
FFeric is offline
Default I want to change the two things I don't like on my Slim
The one thing I didn't like about my Slim was the rear plate holder. The relocation kit that doesn't move the turn signal is ok. But has anyone tired anything else? I have a swing arm bag so that might limit my options.
The other thing I don't like it that plastic that is in front of the rear tire. I thought I saw somewhere on here that someone mentioned something about a way to replace that. The part in the HD catalog says it doesn't fit newer bikes. Has someone found something that works?
Thanks
Old 10-15-2015, 06:01 PM
doc308's Avatar
doc308
doc308 is offline
I am going to remove the side mount from my Slim and install either a vintage style Sparto tail light or tombstone tail light on the rear fender. Another easier thing to do is remove the extension off of the license plate mount and mount the plate vertically.
Old 10-15-2015, 08:54 PM
SLV's Avatar
SLV
SLV is offline
Expensive, but good quality and a good solution to the tag issue.
http://www.greatbikegear.com/index.p...tail-slim.html
Old 10-15-2015, 09:32 PM
FFeric's Avatar
FFeric
FFeric is offline
I been looking around at different side mount plate frames. I looked at the Kuryakyn side mount that attaches to the swing arm. But I don't know if it would work with the swing arm bag. I also found one my TC Brothers. It is an axle mount. I am curious, with an axle mount is mounted to the axle on the inside or the outside of the swing arm? And with a tail light, is there a clean way to run the wires?
http://www.tcbroschoppers.com/led-mo...e-bracket.html
Old 10-16-2015, 02:29 AM
FLS103's Avatar
FLS103
FLS103 is offline
I made an axle mount tag holder, fits just behind my swing arm bag.
Old 10-16-2015, 07:00 AM
mdm's Avatar
mdm
mdm is offline
We put this on my lady's Slim. Good quality and looks good. The LEDs on the plate frame lights up the back of the bike quite a bit. It's a bit over priced, but what isn't today? Are there some states that require the plate to be vertical and not at an angle? Seems like there is but ...
Old 10-16-2015, 08:23 AM
gregeinsc's Avatar
gregeinsc
gregeinsc is offline
Very interested to see how that works out for you if you decide to go with the Tombstone over the Sparto.
Old 10-17-2015, 06:54 AM
WKNDS's Avatar
WKNDS
WKNDS is offline
Received 1,249 Likes on 923 Posts
I you want a "side mount" license plate, then IMHO, an axle mount is the way
to go. It doesn't have to be expensive. I had one on the LH side from
Road 6 Customs, was ~$22.00 and it works with a swingarm bag. Here's a pic;
The swingarm bag just wasn't big enough for me, so I switched it out
for a Rocker quick detach saddlebag. This required relocating the
license plate to the RH side so I used a cheap ~$30 mount I got from Ebay.
I used some CustomDynamics LEDs for platelights. Here's a pic;
Hope this helps,
T.
FFeric
10-20-2015 05:09 PM
Jimmy Dixon
04-20-2014 08:24 AM
ghoticov
04-30-2013 09:14 PM
SouthernGent
11-25-2012 09:52 PM
jasperpso
02-28-2009 10:24 AM
Quick Reply: I want to change the two things I don't like on my Slim
