Could have been worse!
GuessI been replyin in the wrong place to answer a reply.
Not really 80mph I heard the rear cylinder drop I looked down and saw smoke from the breather and I hit the switch and pulled over. right in front of CO, State Patrol.
Looks like pre-ignition or detonation took hold in the motor and caused the piston to self destruct.. Motor should be completely torn down and cleaned and inspected..(piston frags)
A nice chunk in an oil relief or galley would certainly cause catastrophic failure.
Could use a lot better pics of the first ring groove and land..
Not so sure about that.. Without seeing the bearing or crank, it is an unknown.. More likely is the jug is beat silly from the wrist pin dancing around without a piston..
The engine needed to be disassembled (different issue but same parts slapper who did the clutch work) and there was metal chips behind the rotor - chewed up the new stator and all the bearing inside of the primary was also shot - small particles acted like 80 grit sand paper.
