Decided on S&S 509c instead of the S&S 583C
Old 11-11-2015, 09:40 AM
wrathstitz's Avatar
wrathstitz
wrathstitz is offline
Default Decided on S&S 509c instead of the S&S 583C
Okay, so here is the scoop. Ordered a set of the 583C's for my 05 STD and received the 509C instead! Yes I was PO'ed but then right before I was about to return them with a nasty gram I did a bit more homework and decided to go with them and keep things on the mild side of the scale. My riding style played a big part in this decision. Let's put it this way, from July to September I put close to 5K miles on the bike and I want a reliable cam that will not be too hard on the lifter springs.
So here is what is going in the cam chest:
509C's
New roller tappets - Hydraulic
Quickie S&S push rods
Feuling cam plate and their 7000 oil pump
Zippers hydraulic chain tensioners
And, although undecided, an EFI tuner.
What was already on the bike:
SE breather
True duals
Heavy duty clutch spring
These will be installed in the early Spring.
Any thoughts or suggestions to what EFI tuner I should get? No, I ain't got Thundermax cash!! So that is out of the question. And I am computer savvy!
Wrath
Old 11-11-2015, 11:03 AM
Berick's Avatar
Berick
Berick is offline
Tuner - Fuel Moto Powervision...... call them and tell them everything you just told us and they will send you the device with a custom tune already made up for your bike. A lot of guys on here say you only need to run the "Autotune" function on the the programmer 3 times but I found after 7 times it got rid of most of the decel pop. I say run it 6-8 times minimum and you will be happy.
Old 11-11-2015, 11:23 AM
Joe_G's Avatar
Joe_G
Joe_G is offline
I've been tuning cars for years but since our bikes have no 02 sensors and are only speed density I went with a power commander 3 from Fuel Moto. As Berick noted Fuel Moto sends one with a custom tune for your mods based on their experience and they were cheaper than buying direct from DynoJet. Overall a great experience with Fuel Moto.
I think you made a good decision to stick with a smaller cam. I made the mistake of a too big a cam once and it made for a not so fun ride.
Old 11-14-2015, 02:51 PM
oct1949's Avatar
oct1949
oct1949 is offline
yep I think you done good also..
I studied cams for weeks before I choose my Andrews 26H's ... they too are easy on the engine while I ended up with almost 20% increase TQ across the Sheet..
I put them in at 15k and now with 53K the engine still Runs GREAT...and I've not had a single engine issue.....
I went with the older SERT tuner and dyno when I did the Stg1 mods at the 1K service.. mostlyu because back in 07 there was not many to choose from and I wouldn't/will not use a piggyback tuner. Just me...
Old 11-15-2015, 03:19 AM
baloot-boy's Avatar
baloot-boy
baloot-boy is offline
I don't think FuelMoto will have a tune for the S&S 509 cams. I would check with both Dynojet and S&S first if they have a base tune for your setup, then you can autotune over it.
Old 11-15-2015, 06:13 AM
Joe_G's Avatar
Joe_G
Joe_G is offline
I would bet that FuelMoto does have a tune for those cams. Give them an email or a call, their customer support is excellent and I bet they get back to you quickly.
Old 11-15-2015, 06:34 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
Can't see why they wouldn't. Though you may be right... Any idea just how FM goes about developing their index tune lists? I figured it was an open source element built in part by customers and their own in house dyno effort.
Old 11-15-2015, 06:58 AM
Joe_G's Avatar
Joe_G
Joe_G is offline
I'm sure that's how they did it.
And let's be honest, there's not a huge difference in any of these cams, Woods vs SE vs. Andrews, they all follow a basic small, mid and large cam profile. A couple of degrees here or there isn't much and it isn't going to change the tune.
Also, keep in mind the computers on our bikes, with no feedback system, are a nice step above a carb and distributor weights, but it's not that far above that and so the speed density tunes we have are not very complicated.
Old 11-15-2015, 07:10 AM
lionsm13's Avatar
lionsm13
lionsm13 is offline
Received 69,699 Likes on 21,262 Posts
F/M probably goes to the Power CommanderDyno jet site and downloads it the same as anyone can.
Old 11-15-2015, 09:03 AM
baloot-boy's Avatar
baloot-boy
I got my PV from FuelMoto along with my exhaust and AC. Great tune. However, when I added S&S 583 cams they were not able to provide one. I got it from S&S and they worked with me with heat and decel pop.
Quick Reply: Decided on S&S 509c instead of the S&S 583C
