Pro Tuner settings
Old 11-18-2015, 12:43 AM
johnl111's Avatar
johnl111
johnl111 is offline
6th Gear
Default Pro Tuner settings
In Australia our later model softails have an active exhaust valve and air intake valve. The 2015 model, 103ci, stage 1 tune file in the Screaming Eagle Pro Tuner, has the ACR turned off as a default, does anyone know the reasoning behind this?
Also, I can't see any provision for turning off the Active Exhaust Valve or the Air Intake Valve within the Tuner. I know you can wedge the exhaust valve open, but I'd like to turn it off.
Any helpful suggestions would be appreciated
Old 11-18-2015, 05:59 AM
EagleRay's Avatar
EagleRay
EagleRay is offline
I had my dealer install something like a bypass connector/switch for the exhaust valve to keep it open. Cost me € 20,- would be like AUD 30,-
Check google for "exhaust valve eliminator" or
http://vtwinmania.co.uk/product_info...oducts_id=2070
or
https://www.hdforums.com.au/Default....&postid=457267
Old 11-18-2015, 09:04 AM
Fat11Lo's Avatar
Fat11Lo
Fat11Lo is offline
The ACR (Auto Compression Release) is off because a stock engine does not have them installed. I kinda doubt that you have pulled the heads and machined them for ACR's if you are only looking at a Stage One tune. However if you have installed them and the appropriate harnesses then you will need to switch that function to on before you flash your new tune to the bike. As far as the Active Exhaust Valve and Air Intake Valve, I have no experience with that.
Old 11-18-2015, 12:08 PM
SLV's Avatar
SLV
SLV is offline
My 2013 Dyna 103 Street Bob came withACR. The Softails don't?
Old 11-18-2015, 05:05 PM
olongapo1's Avatar
olongapo1
olongapo1 is offline
I recently encountered this on a 2015 Fatboy that I was asked to install a stage 1 on. V&H pipes and a Big Sucker Intake. Had to do a lot of research on Active Intake and Exhaust. In 2011 Harley installed these items on all Export (5HD) models to meet emission and sound level requirements of Australia and European countries. These two features really rob the bike of power.
With Active Intake (Enabled), intake air is restricted at idle and the duration that the fuel injectors are open is shortened. When installing an aftermarket intake it is imperative to disable this ECM function. The new Vance and Hines Fuel Pak allows disabling of the Active Intake and Exhaust. I completely removed the intake and the exhaust to include the servo motor connected to the exhaust butterfly. After installing the new pipes, intake, re-mapping the ECM and disabling the active intake/exhaust, the bike came alive and ran like a raped ape.
Johnl111, in you need more info, I have photos of this modification. Shoot me a mail at olongapo2@gmail.com
Old 11-20-2015, 01:14 AM
Valdemar's Avatar
Valdemar
Valdemar is offline
I have got a 2008 european softail rocker c and the bike have the active exhaust and the active air intake. I changed the air cleaner and I installed aftermarket exhaust, I removed the servo motor and with the power vision, I disabled the active exhaust and the active air intake.
Old 11-22-2015, 06:43 PM
oct1949's Avatar
oct1949
oct1949 is offline
Originally Posted by SLV
My 2013 Dyna 103 Street Bob came with ACR. The Softails don't?
SLV.. I was wondering the same... ???? I'd bet a Google search would clear it up...!!
I know my 07 - 96''er doesn't have them..
A bit too much diff between the 96''ers which I know more about than the newer 103's which I know little about for me to made a comment them
Nazkad
06-03-2013 11:57 AM
Spanky09FatBoy
05-09-2010 08:06 PM
lanceropolis
12-11-2009 02:06 PM
gabhart
08-06-2007 10:36 PM
bjornsson
Exhaust System Topics
16
08-31-2006 08:12 PM
Quick Reply: Pro Tuner settings
